Originally posted by sawitar I have access to some very basic 35mm cameras (viewfinder P&S) but I was wondering if there is a point buying something more sophisticated.
Is MZ-S worth 200 pounds in 2017?
To answer your two questions:
1) The advantages of any SLR, whether film or digital?
a) They are part of a system with many interchangeable parts, the biggest advantage for a Pentaxian is the lens compatibility.
b) Greater range of controls including shutter speed, aperture, and ISO. (slower long exposure times and faster short exposure times, plus bulb; potential f/1.x thru f/32 or f/150+ with a pinhole adapter)
c) Easier to manipulate controls (focus, shutter speed, aperture, ISO, etc)
d) WYSIWYG (what you see is what you get): The viewfinder shows you what your lens is seeing; no parallax issues.
e) Improved ergonomics and weight for more stability.
2) The flagship Nikon and Canon 35mm FSLRs are much more than 200 pounds in 2017. Yes, you could probably find a less expensive compromise such as the Nikon F100 instead of the F5 or F6, but if the MZ-S is in excellent working condition, and the seller will give you some sort of used camera warranty (the best I've seen is keh.com 180 days), then yes, it's worth it, especially to someone with compatible Pentax AF lenses.
