Kodak TRI-X 400 has a very generous exposure range, perfectly suited when metering is not precise - or does not work. These are straight-up automatic scans.
As pointed out, with some highlight adjustments in post processing, I can easily recover a couple more stops.
I suspect that since minilab scanners (Noritsu, Fuji Frontier, Agfa) generally overexpose and overdo contrast and sharpening, that this may have contributed greatly to this look which kinda looks like Techpan.
However, because you're using b&w, you can take a loupe to the frame and visually examine it. If you don't have a loupe and lightbox, reversing a 50mm lens and using a window will work too.
