Hello everyone,
I am in a bit of a Sherlock Holmes case of light leak, and I hope you can help me find the source of it.
I belong to the digital generation but I decided to embrace film and learn the origins and heart of the art. So, I bought a fine PZ-20 / Z-20 camera, second hand of course, but it's in very good conditions. I wanted to use my 35mm DAL and 70mm Limited primes and I needed a camera capable of handling them.
First thing I did when I received the camera was to check for the light seal, it had none. I'm still not completely sure whether the camera needs one or not, but anyway, I bought 1mm thick felt fabric and carefully cut a seal to match the door pattern. Now the door closes snugly and without forcing the hinge. There are a couple of pictures below.
The next thing I did was to load an AGFA CT Precisa 100 color reversal film, that I know is very picky with the exposure and checked all my shots against my light meter. I took some test shoots in a sunny day and it seems that the camera does not have problems nailing the exposure.
Finally I received the developed film, but almost all the photos had these vertical burns. There is also a small rectangular burn between frames 9 and 10 that I think might be the door window. There are some pictures below.
I bought another roll of film, so I have to think carefully on a set of tests that can solve the mystery.
Any help or suggestion is really appreciated.
Thanks!
