Originally posted by Femto1969 Is this as much of a no-brainer as it appears to be?
Yes, this is a decent deal if the lenses are in good+ condition. If it is working, the camera will likely need new foam seals and mirror bumper. A Pentax-A 50/1.7 is worth between $40 and $65 depending on condition and whether the aperture ring is fully functional.* A Pentax-A 28/2.8 is worth between $25 and $35 (ditto for Pentax-M). A Super Program body value is variable. I paid $45 for mine in Ex+ condition (needing seals).
* The Pentax-A 50/1.7 is of plastic construction and the aperture ring has has well-known fault where part of the detent mechanism fails. The result is a ring that cannot be easily moved. Most (all) either suffer from this problem or will fail in the future.
