07-29-2017, 04:59 PM   #1
Difference between Pentax KX and MX???
Does anyone know the difference between the Pentax KX and MX?
So far, all I've found is the size and match-needle vs. led light.
Thanks!!
07-29-2017, 05:11 PM   #2
KX has mirror lockup control.
MX has much larger viewfinder magnification, interchangeable screens and film back.
07-29-2017, 06:39 PM   #3
KX has a depth of field checker
07-29-2017, 06:40 PM   #4
Motor Drive was a special order modification for the KX, so most of them aren't capable of using one. On the MX it was a standard feature and you had a choice of winder (2fps) or motor drive (5fps) that will work with any MX. I find the interchangeable screen to be the nicest feature - I really like to use a grid screen.
07-29-2017, 07:33 PM   #5
K-Three's Avatar
QuoteOriginally posted by Wild Mark Quote
So does the MX,
push the self timer lever toward the lens mount.
I think all the M bodies did this,
MX also has mirror lock up if you gently "tap" the shutter release. Not documented, but a well known feature or quirk.
07-29-2017, 07:40 PM   #6
boriscleto's Avatar
QuoteOriginally posted by K-Three Quote
No. They do not.
07-29-2017, 08:21 PM   #7
pschlute's Avatar
All you need to know is on this site Pentax Camera Bodies
07-29-2017, 09:56 PM   #8
Otis Memorial Pentaxian
QuoteOriginally posted by Viernes Quote
There is more to comparison than a table of features. Implementation details count as do little things such as form factor and suitability to task. I passed on buying an MX new back-in-the-day and have little inclination to own one now. The body in general is a little small for my hands and I found the shutter speed dial difficult to use with camera at eye.
I do own a KX, which I purchased about eight years ago. I have never considered it to be a larger MX despite the similarity in feature set. I like the KX viewfinder style a lot more.*
Some would consider that behavior a bug or a buggy feature, at best (does not work consistently).
* Truth be told, I consider the Nikon FM2 to better than either the KX or MX except that it does not support K-mount.
07-29-2017, 10:09 PM   #9
They are both great cameras. The KX has a much nicer feel to the shutter speed dial. You can actually turn it with one finger while looking through the viewfinder. The KX has mirror lock up as an intentional feature, not an unadvertised magic trick that you must do to get it to work. The KX also has a much nicer meter readout (subjective). The MXs only advantage (subjective) over the KX is that it is smaller.
07-29-2017, 11:12 PM   #10
I've found the MX's viewfinder to qt times be uncomfortably big. The KX also gives you more to hold on to.
07-30-2017, 04:15 AM   #11
I own and like a lot both cameras . I think that the life cycle of KX was too short , due to tendence to miniaturization in ASahi at that time , perhaps forced by the succes of Olympus OM system. In my opinion one of the most important differences is the photocell , since one of the most important features of the MX at that time was its new GPD cell ( Gallium photo diode ) , that according to Pentax , was 1000 times faster than the CdS cells , and completely insensitive to infrared rays , and therefore with better measurement accuracy every time than SPD
07-30-2017, 09:29 AM   #12
ChrisPlatt's Avatar
The MX apparent viewing distance is less. This forces you to move your eye about to see all areas of the image.
The KX screen appears slightly further away and is easier to see in a single glance.
The MX exposure LEDs sometimes seem to disappear in bright light and are an advantage only in near-darkness.
The KX analog match-needle and scale exposure display is more intuitive and far easier to see in moderate to bright light.
My major gripe with the MX finder is that semicircular shutter speed display intrudes deep into the screen,
obscuring part of the viewing area, thus making composing more difficult.
Size matters in this case. IMO the MX suffers over-miniaturization. For ergonomics the KX wins hands down.
Chris
07-30-2017, 10:19 AM   #13
QuoteOriginally posted by jopenmx Quote
Yes, the GPD (MX) vs. SPD (KX) could be a selling point, though hardly a deal breaker. Response speed is less important with a manual metered camera and the accuracy aspect is academic given that the inherent precision of the exposure system on the MX is +/- 0.5 stops and on the KX, +/- 0.25 stops, best case.* If the SPD on my KX (SPD) has an infrared Achilles heel relative to my Super Program (GPD), it is not evident on direct comparison.
* Based on the lack of stepless shutter on both cameras, the MX display (1 stop increments for the LEDs), and the documented limitation of the aperture follower (both cameras) to numerical stops only (e.g. 1/2 stop with most stops on most Pentax lenses).
07-30-2017, 11:11 AM   #14
ChrisPlatt's Avatar
Another difference that should be noted is winder/ motor drive support.
I use my wife's former Pentax MX when I require motorized advance.
My Winder MX advances film at close to 3 fps, far faster than most power winders.
A 5 fps Motor Drive MX was offered as well, but it is rare and has NiCd battery issues.
The standard KX body does not support motorized advance.
A special KX Motor Drive model was offered. It is quite rare.
The so-called "motor drive" barely manages an anemic 2 fps.
Chris
07-30-2017, 12:04 PM   #15
gofour3's Avatar
The MX has a slightly better metering range of 1-19EV (KX 1-18EV).
However the KX has a way better ASA range of 8-6400 (MX 25-1600)
I would pick the KX over the MX as it's bigger and the matching needles are easier to use.
Phil.
comparison, difference, difference between pentax, kx, mx, pentax, pentax kx, size, viewfinder, vs
Micro Contrast and Corner Sharpness difference between 645 35mm A 3.5 MF and HD Joa Pentax Medium Format 10 05-02-2016 05:58 AM
Difference between K3 and K3ii? Moropo Pentax DSLR Discussion 11 02-18-2016 08:14 PM
Pentax K3 such a huge difference in colours. Between DCU and lightroom. Irfanintekhab Digital Processing, Software, and Printing 42 02-02-2016 04:33 AM
Flare resistance difference between 16-50 and 20-40 ? BarryE Pentax SLR Lens Discussion 11 01-22-2016 02:13 AM
What's the difference between the petal lens hoods and the round ones? ZombieArmy Pentax SLR Lens Discussion 35 08-19-2015 03:01 AM
All times are GMT -7. The time now is 02:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
