Originally posted by RustyT Hi
I'm new to film photography and have started using a Pentax MX, which has been fully serviced.
The first film I ran through the camera came out blank. I'm 99% sure that I was being too gentle with it and hadn't loaded the film onto the spool properly and it hadn't wound on.
Someone more familiar with film cameras loaded the 2nd film for me and they were confident it was on the spool properly. However, I know they didn't use the rewind knob to take up the slack in the film. I'm now half way through the film and noticed that the rewind knob was only turning a couple of mm when I advanced the film. I hadn't even though to check this as I shot the first 15 shots!
I suspect again that the film may not have been loaded properly and I have now tensioned the film with the rewind knob and this now turns completely when I advance the film. My questions are;
- Am I right in assuming it's very unlikely the film wasn't loaded properly as the rewind knob was only moving a couple of mm when I advanced the film?
- Having tensioned the film I think I'm now properly on the spool and the film is advancing. The counter is now already showing 15 shots taken. However, assuming I still now have 34+ exposures to shoot, can I continue to shoot even when the counter hits 36...i.e. until the film is actually used up? or will this damage the exposure counter mechanism?
- The MX has lots of white ribs to load the leader into. I just want to check, should I be loading the leader into the left side or right side of the spool? Are there any other MX film loading techniques I should be aware of?
Sorry for the long post and thanks in advance for your help.
Russell
The only safe way is before closing door pin the film to sprocket shaft tooth with thumb and turn rewind knob until the film clinches, then wind film one sprocket tooth while holding rewind knob with lose friction feeling it turn, slam door and wind on watching rewind knob turn...
You always need to watch the rewind knob turn till frame1!
Some film types will counter friction in rewind system and spring back out in cassette again!
