09-28-2017, 05:46 AM   #1
Spodeworld's Avatar
Kodak Tri-X 400 or T-Max 400?
Hi. Just picked up a Spotmatic. Would like to do some B&W and was wondering which of the above you guys prefer and why. Thanks
09-28-2017, 05:54 AM   #2
The Tri-X 400 has a more "classic film" feeling. The T-Max 400 can produce higher quality.
09-28-2017, 06:00 AM   #3
Spodeworld's Avatar
Higher quality in what way?
QuoteOriginally posted by 08amczb Quote
09-28-2017, 06:07 AM - 1 Like   #4
T-Max has finer grain so it has higher resolution wich makes sharper images. I consider the resolution boost marginal in small prints. It needs care and accuracy at developping.
09-28-2017, 06:18 AM   #5
derelict's Avatar
For messing around, Tri X has a lot more latitude and is more flexible. For taking photos of everything else, TMax is better.
09-28-2017, 07:34 AM   #6
twilhelm's Avatar
As derelict stated, Tri X has a lot of working latitude. I keep a 100' roll and it is quite affordable. T max will give you finer grain and sharper images. I'd recommend trying both.
09-28-2017, 07:36 AM   #7
Spodeworld's Avatar
Sounds like TMax has the edge if you are careful in what you do.
09-28-2017, 08:11 AM - 1 Like   #8
gofour3's Avatar
Buy a roll of each and see which you prefer, that would be my recommendation. I've used both and don't have a favourite.
Phil.
09-28-2017, 08:32 AM   #9
I have far more experience with Tmax than TriX, and I would go for Tmax again if I hadn't already bought 100ft of Kentmere 400 to play with. (Why? Because I wanted to try bulk loading and I wanted to be able to do short rolls for experiments in developing, and Tmax was horrendously expensive in that format.) Among other things, I have just worked out how to develop it in Caffenol C - and given that TriX is said to require TEN extra minutes in that soup (35 minutes in total!!!) I don't want to go there.
09-28-2017, 09:06 AM   #10
Jellygeist's Avatar
I quite like TriX, personally. Looks classic, nice and grainy, nice contrast. TMax is too clinical for my taste, but you may like it.
09-28-2017, 10:02 AM   #11
murrelet's Avatar
I mainly use Ilford instead of Kodak for BW. But I'll throw in my $0.02... HP5 > Delta 100 > Delta 400. I don't develop myself (yet) so I'm probably not making the most out of Delta. I imagine if I used Kodak, my preference would be similar: Tri-X > T-Max 100 > T-Max 400.
09-28-2017, 10:24 AM   #12
Alex645's Avatar
QuoteOriginally posted by Spodeworld Quote
I would agree with every previous post. Here are a couple more ideas to consider:
Tri-X is much more consistent with different developers. TMax is compatible with traditional developers, but to really produces enhanced shadow detail, you need to use Kodak TMax developer: https://www.bhphotovideo.com/c/product/29117-REG/Kodak_8446163_T_Max_RS_Developer.html
If you have any experience with Ilford films, the difference between Tri-X and TMax is like the difference between HP5+ and Delta 400.
A great tool to 'preview' the tonal response, contrast, dynamic range, and grain will look like can be done on Nik Collection's free Silver Efex Pro 2. If you take a jpeg and open it in this free app, on the right side there is a "Film Types" menu that include both Tri-X and TMax and it will show you a simulation of how the two films would produce different gray scale results. Note: There are a ton of developer manipulation that can alter your actual results.
Google Nik Collection
09-28-2017, 12:56 PM   #13
UncleVanya's Avatar
I shot a lot of HP5 and Tri-X pushed to 3200 a long time ago. Nostalgia says Tri-X for the win over T-Max. I do agree that T-Max can seem a little more clinical but honestly shoot two rolls and develop as you plan and compare - my memory is not working off current data.
09-28-2017, 02:52 PM   #14
I shudder to think how long I would have to bake TriX in caffenol for 3200 ASA. I suspect some quite significant (semi-)stand development would be required.
09-28-2017, 03:05 PM   #15
UncleVanya's Avatar
QuoteOriginally posted by pathdoc Quote
Never used caffenol back then. Dektol is what I recall using.
kodak tri-x
TMax 400 vs. Tri-X; pros and cons of switching pathdoc Film Processing, Scanning, and Darkroom 30 07-14-2017 08:35 AM
Black & White Old Kodak Tri X Portrait crabby Post Your Photos! 2 07-30-2014 05:41 AM
Kodak T-Max P3200 Film photographyguy74 Film SLRs and Compact Film Cameras 16 12-23-2013 04:57 PM
Blast from the past: Kodak Tri-Chem Pack ChrisPlatt Digital Processing, Software, and Printing 15 04-30-2012 05:13 AM
All times are GMT -7. The time now is 04:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
