08-27-2008, 12:32 PM   #1
More newb help!
Just took my forst roll of film to get developed.. came back and the film had nothing on it. I have an Asahi Pentax ME don't really know anything about it . thougt i would just load the film and be able to shoot. What did i miss??
thank you
jack
08-27-2008, 12:34 PM   #2
Banned
did you read the manual? its likely the film wasn't loaded properly thus wasn't advancing. but I cant really say to be honest without seeing what you did and the camera itself.
08-27-2008, 12:40 PM   #3
didn't come with a manual i am sure it is user error no doubt..is there an online manual?
08-27-2008, 12:43 PM   #4
Banned
http://www.pentax-manuals.com/manuals/mf/pentax_me_manual_s.pdf
Password: Pentax (case sensitive) can be downloaded for later reference.
08-27-2008, 01:34 PM   #5
thank you !
08-27-2008, 06:26 PM   #6
Wheatfield's Avatar
QuoteOriginally posted by bruloup Quote
thank you
jack
Probably the loading the film part. It's a good idea when you load a film to turn the rewind crank backwards after the door is closed to take up the slack in the film, then when you do the pre advances to move the light struck film off the exposure window, you can see the rewind crank turning, indicating the film is moving.
08-27-2008, 11:53 PM   #7
titrisol's Avatar
Location: In the most populated state... state of denial
Let's see
- Was the roll loaded properly?
You have to put the "tongue"inside the slit in the take up spool (or between two of those white rollers)
- Did you put fresh batteries on the camera?
2 AG13/SR76 are needed
Check if the lights on the viewfinder go on
- did you hear a clik-clack every time you took a picture?
08-28-2008, 01:40 PM   #8
I def need new batteries and prolly didnt load the film correctly either. Will pick up stuff today and see what happens _
thanks all
jack
08-29-2008, 05:09 AM   #9
Banned
good luck my friend!
08-29-2008, 07:18 AM   #10
titrisol's Avatar
thanks all
jack
I checked my MESuper last night, and without batteries it just works on 125X
I'm quite surprised you were able to advance the lever wothout the shutter being triggered.
08-29-2008, 07:43 AM   #11
KungPOW's Avatar
I think the ME allows a fixed shutter speed of 1/100 without batteries.
If the LED's flash or flicker, then you need new batteries.
08-29-2008, 07:48 AM   #12
Banned
correct. the mechanical shutter speed on the ME is 1/100 the ME Super is 1/125.
08-29-2008, 10:07 AM   #13
Check the negatives. Are there any frames markings, or is the whole thing one shade. If there are no frame spaces, i suspect film advance,. Next time load the film, close the back and tighten the rewind knob. When you advance the filem lever the knob will spin.
Dave
film
Newb natestation Welcomes and Introductions 3 08-12-2010 10:20 PM
picasa ? from newb iggy373 Troubleshooting and Beginner Help 14 12-23-2009 01:39 PM
Newb with K-x questions DSLRnoob Pentax DSLR Discussion 6 10-26-2009 09:56 PM
im a newb cguit Post Your Photos! 11 05-21-2009 04:23 AM
Newb question..... shawn474 Troubleshooting and Beginner Help 9 03-04-2009 08:06 PM
All times are GMT -7. The time now is 06:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
