Originally posted by conniption Hi all, I just picked up a K2dmd in really nice condition. The only challenge is that the meter won't engage when the shutter button is half pressed to the detent, but will engage when the button is pressed a little more, but won't stay engaged when the extra pressure is released. Has anyone else experienced this problem?
Seems like it should be a simple fix.
Also, should the meter needle move in auto mode? I think it stays at the top on my K2.
Is this a feature of the exposure lock function?
Exact same thing happened while I was using one of my K2DMD's a few years back.
What's supposed to happen is you cock the rapid-wind lever and press the shutter button half-way, the meter will turn on and stay on. But mine stopped working properly and when you took your finger off the shutter button the meter also turned off.
A trip to Eric's fixed the problem. This is what Eric indicated::
The advance detent is probably broken therefore not keeping the advance lever to the on position
Phil.
