Originally posted by microlight Version 2 of the original Spottie, in nice condition and sporting a very nice SuperTak 50mm/F1.4! Serial 259xxxx puts it around 1966-68 vintage. It should have an ASA range of 20-1600, with 23102 engraved on the base plate. Version 1 was 1964, serial 100xxxx to 150xxxx with an ASA range of 10-800 and 231 on the base plate.
Interesting. I have in front of me an AOC SP
- Serial 123xxxx
- 23102 on the right rear edge of the base
- ASA 20-1600
- Top attachment screw (slotted) at the side (3 o'clock) under wind lever
- No film door roller
- Meter switch with "red window"
- Short frame counter
The model number pins the body as "late", while the serial number is "early". Apparently there is some overlap of the serial number ranges as well as the parts-mix. My camera...
I believe this photo lifted from an old eBay auction shows an early Spotmatic; note
top screw location and tall frame counter...
