Originally posted by HansrajVyas Thanks, all of you for your prompt responses. The battery is Varta 6v lithium and on voltage meter it shows full 6v power. It works fine on my Z-70. However, I am getting Sanyo lithium one and shall try it shortly. I have cleaned camera and battery contacts. The mirror position is down, as it should be, prior to firing the shutter. The specifications on Operating Manual says- battery exhaution symbol blinks when the shutter is locked and no indication on the right hand edge of the view finder. In my case the battery symbol keeps blinking- could it be a case of shutter locked ?
Most volt meters don't measure voltage under load. I've seen it a number of times with Li Ion batteries, because their usage curve is so flat. It's akin to the old mercury cells.
