Originally posted by stevebrot Truly, what you are doing is no different than what is done by used camera shops the world over. Where things get complicated is when the general supply of used parts and repairable used cameras becomes more dear for what should be more desirable models. Scavenging a fairly rare Spotmatic F* or even a more common KM in working or salvageable condition to fix a common-as-crows, made-in-China** K1000 tends to ruffle feathers on a fan site, so be prepared for some push-back. OTOH, using a compatible "parts only" body as a generic donor makes perfect sense to me if the parts are truly the same. Even better is if the body is fully parted out. When/if you are able to confirm common part numbers for the prisms, please share the information. It will be useful in general.
(...have noticed a severe decline in usable film cameras here locally in the last year or so...have also noticed that prices for working Spotmatics in good condition is rising...)
* I say fairly rare because I have never seen one in the wild or in a shop despite a decade or so of scouting around for that kind of thing.
** The prism desilvering issue seems to be limited to later production K1000, specifically those produced in China.
If I manage to find out the part numbers I will definitely share. It would be very useful for everyone to know.
As for sacrilegious behaviours (in the eye of a 'fan') all I can say is guilty as charged. But the reality is there are fewer and fewer parts available for these old cameras (including K1000's) and one has to improvise. On that note, my observations are:
- Spotmatic F prisms are vulnerable to desilvering. Two of mine have this problem.
- KM prisms are vulnerable to desilvering too. It might be 20% of the cameras I have/ had that were inflicted.
- Non Chinese K1000 prisms have a lower rate of desilvering than the Chinese models. Appears to be a similar rate to the KM prisms.
Desilvering is an inevitable outcome for these parts. The glue and foam attached to the prisms deteriorate and fall off. IN so doing, it may take away the attached silvering thus degrading the prism. Nothing will stop this process with age of camera probably enhancing the prevalence. On this basis, there will be a major shortage of prisms in the foreseeable future as repairs such as those I propose eat away at the bank of spare parts available in old bodies.
The real solution to this problem is getting prisms made for these ailing cameras. On that score, my interim thought is to keep the damaged prisms and consider restoration - I am actually seriously considering this step as I type but cost will be an issue.
