It has been mentioned on TOP and on other film photography sites that anyone using this film should have it developed ASAP after you have finished the roll for the best image quality. I will also point out that High speed films are designed to give the highest speeds with the lowest contrast, by all means expose at box speed - but remember : a little overexposure never hurts with negative films, Since most people are developing their own films here making your own judgements on EI can help get the results that you want.
Originally posted by gutter rock TMax 100, at least in 120 size had a manufacturing problem with the backing paper
As I recall they were using the thicker Estar base and this was burning out the auto winder motors on modern MF cameras, the pressure plates were exerting quite a bit of force that required a lot of torque to overcome.
