Originally posted by TomB_tx It's not unusual to have such variation if all traces of old lubricant aren't thoroughly flushed out before applying the proper lubes. Ideally this is by disassembling so the ends of shafts and inside of bearings can be completely cleaned. I had similar issues with a 60's Pentax that I tried to clean without total disassembly, so I sent it to Eric. He sent back a photo of it on his bench with the shutter completely torn down. It has been fine for years since.
If this isn't done, and you try to adjust the curtain tension to overcome excess friction in the bearings, it is quite possible to over-tension and stress the springs so they begin to relax. Ideally, once the bearings are fully cleaned and re-lubed, the spring tension should be set by timing the curtain speed of each curtain, and setting tension no higher than necessary.
Often you can get acceptable performance with a lesser clean and "tweaks" - but sometimes a true disassembly and service is necessary.
Thanks TomB for your ideas, seems like you've opened a few of these cameras
It does make sense what you are saying. I did disassemble my camera almost completely except for I did not remove curtains / curtain shafts because the spotmatic repair manual stated, "...pipes containing curtain springs should never be immersed in cleaning liquid..." So I thought I should not touch them, but I did lubricate the ends of curtain shafts in their holes. I have a zombie spotmatic lying around, I shall take the curtains out and see if I can clean it and lubricate and make it work properly. On a re-read of the manual I noticed mentioning of the tolerances between the shafts and retaining plates -- "Check if the clearance between the pinion shaft collar (05135) and the top mec. plate (03001) along the shaft
direction is adequate. The pinion shaft will not rotate smoothly without an adequate clearance. Adjustment of
the clearance should be made with (W6) washers." . This could be it. I have nothing against Eric, but I would like to repair my cameras myself. I think better understanding the build of the camera makes me a better photographer. Thanks again!
---------- Post added 03-01-18 at 10:13 PM ----------
Originally posted by stevebrot My understanding is this is normal behavior for long-dormat and retensioned mechanical horizontal shutters regardless of brand. My camera tech explained this to me several years ago along with the observation that it was a "pain in the ****". With exercise, the shutter should even out, if I understood him correctly.
Hi Steve, thanks! Sounds just like Italian tune up on my 1984 Mercedes Benz 300d. If it's choking and strutting and stalling and jerking and rattling, you just drive it for a 1000 miles and it will tune itself up! LOL. If it works out like this for my spotmatic, I am buying you a drink!
