The original cable F switch uses a three pin connector with 1/10 inch pin spacings and allows focusing by pressing the release half-way, just like the camera shutter release (it even has a little click indent at the half-way position). Connectors which will fit the PZ-1p are readily available from electronic parts outlets but they might need some adapting. The actual cable F connector is rectangular with one corner lopped off. The flat end pin is the common, the middle connects to the common for the full cable F button depression, and the pin on the lopped off end connects to the common for half & full press positions of the cable F button.
Another benefit of the cable F cable release is that it has a locking switch which can be used for bulb exposures and locks the main button in the down position until the locking switch is flipped the opposite way (which releases it and returns the cable release to normal operation).
The cable F gives you about 41 inches of reach.
I would advise just getting a used cable F release as long as it's available unless you need more of an extension or want to interface with a wireless system etc....
With a couple of relays and some electronics, you can make some interesting control circuits that emulate the cable F release. Examples would be motion detector shutter triggering or a long distance wireless shutter release.
