Originally posted by stevebrot Time to start believing. I have an Exacta VXIIa (Varex IIa) that supports M, FP, and X sync. It was made in 1957 and is very much mechanical in every aspect. The Pentax Spotmatic also supports both X and FP and instructions on how to adjust the points are in the PDF manual available at the Pentax Manuals Web site:
I meant that I found it hard to believe that the shutter would be
deliberately delayed to allow the flash bulb to get going; because people want the shutter to fire asap when they press the button. Indeed it is not deliberately delayed, as your link to the Spotmatic service manual shows.
Thanks for that link, and it answers my question. The X trigger is by means of the first shutter curtain fully opening, as expected. The FP trigger is by means of the mirror reaching its almost fully up position (3mm short of it in fact) which will be slightly earlier, giving time for an FP flash bulb to get going. The X trigger actually requires both the mirror and the shutter contacts to be made. The diagrams on Page 51 (the last) are the most telling, the last diagram being the circuit diagram.
---------- Post added 03-16-18 at 04:41 PM ----------
Originally posted by UncleVanya Are you talking about a PC socket? My K-3 has that. I'm not sure I am following you.
A Prontor/Compur [PC] socket is the physical miniature co-axial socket to connect an external flash via a lead, and most DSLRs have one, and some older film SLRs had two (possibly even three). However, the PC standard AFAIK does not define how exactly it is used, and there are at least three types of use : M, FP and X (as Stevebrot mentioned). On modern cameras only the X type is used, being for modern electronic flashguns. The M and FP types were for two different types of glass flash bulbs which naturally modern cameras do not support. Ther is no physical difference between M, FP and X PC sockets, only the electronics behind them, so on cameras with more than one they are marked (eg on the LX and KM). My father had a 1950's camera with a single PC socket but a switch that changed it between M and X types. Hope that helps.
