I have got a Spotmatic for parts because the advance lever was stuck. I have fixed that, also have cleansed and lubricated a bit the mechanism, cleansed focus screen, mirror, viewfinder. So i have an extra functional Spotmatic
I try now to fix the base plate. The inside of the battery cover was covered in green corrosion. Was this from old mercury oxide batteries? I have just scratched away most of the corrosion with a blade but the covr is stuck. Some former owner tried hard to unscrew it. By the color it looks like coated (or plated?) brass and the whole base plate may be the same metal.
Some chemical would be needed to unlock this. Just don't know what to use: an acidic or a basic one?
(pictures taken with the Super Takumar 1:4/100mm at f16 in M mode, iso 200 with a K-5)
