Originally posted by timw4mail So, is there a copy of the Tamron adapter that works with open-aperture metering, or is open-aperture metering just finicky with Adaptall lenses?
Your adapter is designed to support open-aperture metering, but will only do so properly if in good working condition, including the coupling tabs (lug) with the tabs engaged to the lens. I have several Adaptall-2 lenses and a collection of adapters for different mounts (mostly Adaptall-2, but one Adaptall) and all engage easily with no tendency to pop out. None seat themselves auto-magically, though often enough they will do so if the lens is attached according to Tamron instructions.* If the tab is not seated, it is easy enough to slide it into place BEFORE mounting to the camera.
* The instructions are increasingly hard to come by, but in simplest terms, the aperture ring on the lens should be set to the
widest aperture for both attaching and detaching the adapter. This is particularly important for adapters such as the PKA where mechanical interlocks may be wrong with improper attachment/detachment.
