09-13-2018, 11:53 AM   #16
QuoteOriginally posted by bobbotron Quote
I believe this to be a straw man argument, at least here in Canada. Concert venue == private property. Public place, I'd tell authority XYZ I'm in the right, and what was your badge number?
The public place thing is the same in the US as Canada... in theory.
It may be too late to get some, but I like the appearance of the grain of Tmax 3200 (at 3200).
09-13-2018, 12:45 PM   #17
bobbotron's Avatar
Sure, private property is different. But in your case I suspect no matter how belligerent people with phone cameras could be they still would not ban them like presumably they did with the larger gear. So I'm still standing by my camera discrimination thing.
FYI, that scenario I described happen to me. Guilty until proven innocent is the mindset around here.
Fair enough! I guess for me, I'm not going to fight it for a concert, but in day to day life I feel photographers rights are pretty well entrenched in public places.
---------- Post added 09-13-18 at 03:47 PM ----------
QuoteOriginally posted by dsmithhfx Quote
Yes and I wish I had one (or any film RF with a fast lens) -- unfortunately they all seem to be pricey now. Dunno if I'd bother with concert shooting though.
I can remember when they'd all be waving bic lighters, well before smartphones came along.
I lucked out with the Petri, bought it for $30 Canadian. It's a nice camera, only gripe is that I find the film reel to be almost impossible to load, massively frustrating each time I need to change film.
09-13-2018, 12:57 PM   #18
dsmithhfx's Avatar
Is that by design or is something a bit broken?
09-13-2018, 01:04 PM   #19
bobbotron's Avatar
The way you slip it in, it's such a pain to get it to start taking up the film. It just seems like a really fidgety design.
09-13-2018, 01:48 PM   #20
UncleVanya's Avatar
Some cameras were really bad at that. Some were so easy it was funny. I never could get a bead on why some were so badly designed.
09-13-2018, 04:35 PM   #21
The famous Leica M3, M2 (and earlier) required you to remove the camera bottom plate, pull out the film take-up spool. Insert the film leader (aligned carefully) under a spring clip, then pull out enough film to simultaneously insert both the cassette and take-up spool into their chambers through the camera bottom, install the bottom plate and lock it in place.
Canon rangefinders before about 1955 were the same, but went to back loading in the late 1950s.
Leica still required removing and threading the take-up spool until the M4 in about 1968, and you still have to load through the bottom even with the film cameras made now.
(And even the latest M10 digital removes the bottom plate to change the SD card.)
09-13-2018, 06:21 PM   #22
But, but...Leica!
I have a lot of respect for Leica, but it is amusing reading leicaphiles explaining that it’s no big deal to pre-trim the leader on all thier film rolls so when they’re out the can “quickly” change rolls.
On the other end, I find it amusing all the effort that went into trying to make loading film easier, which basically amounted to automating the “push the leader into the takeup reel” part of the process. I’ve found those efforts less than perfectly reliable. Several times my F4 didn’t catch the leader, and didn’t advance the film, the Canonet has been reliable but has this big flap that actually makes it harder for me because I can’t see if the sprocket holes are lined up.
09-14-2018, 05:44 AM   #23
dsmithhfx's Avatar
QuoteOriginally posted by abruzzi Quote
But, but...Leica!
The easiest to load IME was the olympus stylus epic. You just had to drape the leader across the take-up spool and close the back . I had two, one the autowind died, and the replacement I lost quite recently (the loss tempered by worsening and irreparable light leaks from around the lens mount).
09-14-2018, 07:49 AM   #24
The Canon EOS 3 is like that. You can also set a fast or slow rewind and can chose to leave the leader in or out on rewind.
09-14-2018, 08:14 AM   #25
The Canon QL (Quick Load) system used on the Pellix QL and FT-QL (and others) in the mid 1960s was like that, but manual wind. The take-up spool had 3 spring-loaded arms with rubber grippers. You laid the film leader over the spool, and as you closed the back another flap held it in place, Then just advance to the first shot. I had an FT-QL about 1966. Very nice loading system (and nice camera).
09-14-2018, 08:19 AM   #26
dsmithhfx's Avatar
QuoteOriginally posted by Vendee Quote
Yeah, now that you mention it, my Rebel-TI and Sigma SA-7 also had similar ease of loading. I stopped using those cameras many years ago, but kept the stylus as my 'walking-around' camera (always with me). Now I need to find a replacement. I guess. I kind of didn't use it all that much in the past few years except as a backup (or alternate film) camera.
09-14-2018, 09:31 AM   #27
QuoteOriginally posted by TomB_tx Quote
Maybe I'm the only person that has problem with the Canon QL system...
09-14-2018, 09:55 AM   #28
bobbotron's Avatar
I have a pentax PZ-10 that's pretty slick to load and unload, but not quite that nice!
Fyi thanks for all the suggestions. I shot at 1600. Didn't get that many shots but hopefully a few keepers.
09-14-2018, 12:06 PM   #29
Good or bad post some results.
09-14-2018, 12:08 PM   #30
UncleVanya's Avatar
PZ-1 works much the same, leader in or out at least. Super easy to load.
Glad 1600 was OK. That's a better IQ ISO with Tri-X in my opinion.
camera, concert, contrast, day, film, fun, iso, lens, petri, pm, post, shots, stage
Fuji Neopan Acros pushed to EI 640 gabriel_bc Film Processing, Scanning, and Darkroom 6 10-30-2016 06:38 AM
Lindsey Stirling concert tonight. Boise, Idaho Dewman General Talk 3 05-26-2015 01:05 PM
Pentax EI-100: A blast from the past! ChrisPlatt Pentax Compact Cameras 1 08-11-2008 01:02 PM
1st Equestrian event since EI Mechan1k Post Your Photos! 14 03-30-2008 10:22 PM
All times are GMT -7. The time now is 09:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
