09-17-2018, 05:48 PM - 2 Likes   #31
QuoteOriginally posted by Mikheil88 Quote
Automatic mode and 25$ price tags aren't a necessity, but I would much rather invest in proper optics than the body, hence "the cheaper the better". If I find MX for 50$, I'll go for it. XR7 is somewhat cheap too, I've seen one for 20$-ish. I have also seen a few ME Supers for 30-35$ and oddly enough Super Program which is newer and has more features were going for 25$. Don't know about the rest.
The XR7 is a good alternative to the ME Super with having traditional controls. Unlike the ME Super, it is fully battery dependent with no mechanical speed available when they die. I managed to get mine in the price range you are looking for although I didn't encounter it often.
You'll notice in the ad it states, aluminum diecast body and not plastic. It is well built and feels good in quality.
Another member here - Steve, has a collection of Ricohs -> 3rd Party K-mount Cameras
---------- Post added 09-17-18 at 07:58 PM ----------
I haven't had XG-M, but I had X-700 for a while. I wish it had a build quality of Mino SRT.
I have an X-700 given to me by a friend and it is clearly the most advanced manual focus camera I have with remote and intervalometer back. If you prefer a better feeling/built body then the XD-11 or XE-7 might be a consideration.
I find the XE-7 to have the smoothest film advance of any camera I have tried. It really does have to be tried.
---------- Post added 09-17-18 at 08:03 PM ----------
They are fairly easy to find out here too, it's just me who is forgetful. OM bodies drain batteries like a glass of juice and I had to deal with all-mechanical speed more than once. Pentax is far better in that.
It is too bad that your OM bodies have that issue. Otherwise, I would be hard pressed to trade mine for any other system especially because of the spot metering mode which I prefer to use.
Not that I would trade any of mine even if none of them are perfect . . .
09-17-2018, 11:13 PM   #32
Mikheil88's Avatar
QuoteOriginally posted by johnha Quote
The only camera not yet mentioned that might be an option is the original P30 - the only issue perhaps is it's reliant on DX coding. The body is mostly metal (only the top-plate & finger grip seem to be plastic), it has a shutter speed dial, meter lock (a rarity in Pentax MF bodies), takes a mechanical cable release and shouldn't be hard to find for a reasonable price. The later P30n/T are probably more plasticky.
RIght, I forgot about it and frankly I thought it was plastic judging from the pictures. Looks can be deceiving.
QuoteOriginally posted by LesDMess Quote
All are valid points, I should look at old washed-out ads more often than I do now. The one and only Ricoh I ever held belongs to my friend and it's KR5 Super II, a rather loud and clunky mechanical camera. But if I recall correctly ME Super was also noisy.
I can't really tell what I did not like about X-700. Function-wise it is good, although "P" mode is not something I would use and therefore X-570 would suffice. 4 seconds maximum automatic shutter speed is a tad small, I used cable release and bulb mode quite often. "A" mode lock was something I never got used to, even though I understand the reason behind it.
None of my current OM bodies have the issue, but I had several OM-1, OM-2, one OM-2s in the past and more than enough quantity of them suffered from the issue. I had to change idler gears to get rid of the problem. And I fully agree about spot metering mode, that is the only feature which will truly be missed by me. However, I will still have Nikon F80 so if uncertain or in the need of Spot meter, I can use it.
I think I will settle for ME Super again, or for MX if I find either of those at a price seemingly reasonable for me. But from what I've researched so far, obtaining lenses for cheap is much more difficult than finding a body.
09-18-2018, 03:40 AM   #33
Wasp's Avatar
I would get the the MX. It is all mechanical, robust, compact and has nice things like interchangeable focusing screens, data back and motor drive/winder compatibility.
09-18-2018, 06:04 AM   #34
Mikheil88's Avatar
QuoteOriginally posted by Wasp Quote
I think I'm slowly reachig the same conclusion. I'm not a guy of data backs and motordrives, but small size and mechanical operation are very welcome.
09-18-2018, 04:38 PM   #35
Make sure that you add the cost of a CLA to your budget. That is, if you don't get an invoice from the seller showing that it was done recently anyway.
09-18-2018, 04:54 PM   #36
Pentax MX is the smallest full info viewfinder fully mechanical SLR that happens to also the have largest viewfinder.
09-18-2018, 09:00 PM   #37
Mikheil88's Avatar
QuoteOriginally posted by ctrout Quote
I usually do CLA myself.
Indeed, Judas' window makes the difference. X-700 has it too. Pretty convenient when lenses have internediate clicks between the stops.
09-21-2018, 11:13 PM   #38
Mikheil88's Avatar
I won "M" version of 28 mm f/3.5 lens two days ago for 18$, I think the price wasn't high. It'll work well on my K-x as a 42 mm lens and in the meantime I will look out for either MX or ME Super (again).
10-14-2018, 10:09 AM   #39
Mikheil88's Avatar
Another question: I've learned that Pentax MX, ME, ME Super and other M series bodies suffer from wind lever / mirror issues, which are manifested either in not cocking the shutter, or some not so funny business with the mirror. So do you know if Pentax Program A (aka Program Plus) and Pentax Super A (aka Super Program) suffer from the same issue, or are they trouble-free?
P.S. SMC Pentax-M 28 mm f/3.5 is razor sharp and produces outstanding images on APS-C sensor. I'm sure it will shine on full frame film body as well.
10-14-2018, 10:37 AM   #40
johnha's Avatar
Any problems with M series wind-on levers is almost certainly overblown and much less prevalent that electronic issues with the Super-A. The Super-A is a great camera but I've had all sorts of intermittent problems from the mode dial and/or delivery of power from the battery. Often the bulb to illuminate the LCD works but there's no other power in the camera (the top-plate LCD doesn't show the wound-on indicator). Sometimes brand new, fresh batteries fix it, sometimes it doesn't. The ME Super electronics and meter in the MX are much simpler and more likely to be reliable in 40+ year old cameras.
10-14-2018, 10:49 AM   #41
Mikheil88's Avatar
I had ME Super around a year ago and it wouldn't cock the shutter after film advance, roughly once in every 20 frames. Regular ME which I had before didn't have that issue at all but results vary from sample to sample. I guess when you're 40+ years old and don't visit a doctor, some malfunctions are inevitable.
Thank you for the useful information, I'll keep an eye out for something suitable. I'm a little nervous because I've only serviced Olympus cameras and most of their issues were mechanical, not electronic, I have no experience with Pentax yet.
10-15-2018, 12:03 AM   #42
womble's Avatar
I've had /have well over a dozen M series bodies and have yet to come across that problem.
10-15-2018, 05:01 AM   #43
The Super A ist the camera I would have recommended instead of the ME Super.
It is the better camera (I have them both) but it has it's own issue.
The A series introduced the electronic contacts in the bayonett. The issue a Super A might have is the malfunction of these contacts (mine has). The result will be unreliable metering when the aperture ring of the lens is set to A. I think it will work if you set the aperture to any other value, but I'am not sure about this. My Super A worked very well when it was my main camera and I found out about the issue just last year, when I tried if it still works.
Of course manual setting still works, but where is the point in a Super A, that only works in manual mode?
Other kown issues are: LCD lighting will not work and yes, there are problems firing the camera as well.
If you get one in working condition I would recommend it over the ME super, as it has the same features plus DOF preview, programm mode, aperture priority, TTL flash.
10-15-2018, 05:02 AM   #44
ChrisPlatt's Avatar
After dabbling in Ricoh/Sears K-mount cameras my first Pentax was a KX.
I tried practically all the Pentax manual focus models as well as a few AF.
The K series Pentax bodies are my favorites. KX, KM, and K2DMD are my keepers.
Chris
10-15-2018, 05:03 AM   #45
Mikheil88's Avatar
QuoteOriginally posted by Papa_Joe Quote
Of course manual setting still works, but where is the point in a Super A, that noly works on manual mode?
Other issues are: LCD lighting will not work and yes, there are problems firing the camera as well.
I think I'll just skip everything and go to Ricoh XR-7 at this point. I have only one lens with Pentax "A" contact and I control aperture manually even on that.
---------- Post added 15-10-18 at 04:05 PM ----------
QuoteOriginally posted by ChrisPlatt Quote
Chris
Yeah, those would be my keepers as well if they were cheaper, or lighter. Or both.
batteries, bodies, body, camera, cameras, film, k-mount, k1000, k2, km, kx, lens, lenses, mm, mode, mx, olympus, om-1, pentax, price, quality, range, ricoh, secs, speeds, time, trade, x-700
Help picking a walk-about shoulder bag Erictator Pentax Camera and Field Accessories 22 05-12-2018 06:32 PM
Picking out FF K mount landscape lenses motorhead9999 Pentax Full Frame 42 11-09-2017 06:14 AM
Help picking up a setup! R3dux Pentax SLR Lens Discussion 18 11-01-2010 09:19 AM
Need help picking a wide angle TOUGEFC Pentax SLR Lens Discussion 16 04-14-2010 03:24 PM
I need help picking a flash perception-of-light Flashes, Lighting, and Studio 5 02-19-2010 03:35 PM
All times are GMT -7. The time now is 03:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
