09-23-2018, 04:26 PM   #1
MX light leak
Dear brains trust, any ideas where my light leak is?
MX and SMC-Tak 50/f1.4
I suspect I would have shot this with the shutter-release down
09-23-2018, 04:46 PM   #2
Swift1's Avatar
I find light leaks to be nearly impossible to accurately diagnose, but I'll have a go...
The leak runs top to bottom and isn't really stronger on either the top or the bottom, so that would seem to rule out the top and bottom of the film door.
Does the leak run across the entire negative, outside the frame?
If yes, I would suspect the leak is on the hinge end of the film door.
09-23-2018, 05:21 PM - 1 Like   #3
Not a Number's Avatar
Just replace them all. If one goes bad the rest will follow sooner or later. A light seal kit will give you material for all the seals and the mirror bumper. Why only replace one seal then ruin a few rolls of film when the next one(s) starts leaking?
If you really need to know get a small keychain flashlight/torch that will fit in the film compartment, turn it on, close the camera and go into a dark room.
09-23-2018, 06:37 PM   #4
photoptimist's Avatar
Left side of the frame means the leak is on the right side of the camera.
If the leak is entirely confined to the frame (that is it is not in the filling gap between frames or bleeding across the sprocket hole margins), then the leak is in the front of the camera. If so, check the shutter both after firing and after cocking.
09-23-2018, 08:48 PM   #5
Otis Memorial Pentaxian
Second curtain slow at end of travel? The first example looks that way.
A hinge leak would show at different points of each frame as a band with differing amounts of intensity depending on position in the roll and the amount of time between shots (...has strongest effect on the rolled up film on the take-up side).
09-23-2018, 11:25 PM   #6
Because it may not be seals (see the above comments regarding the shutter).
---------- Post added 09-24-2018 at 04:27 PM ----------
Thanks for your comments. When you say check the shutter, what am I checking?
09-24-2018, 06:15 AM   #7
QuoteOriginally posted by nickthetasmaniac Quote
Remove the lens, open the back, point the camera toward the sky and then look for light coming through the shutter or at the edge after firing and during cocking. If the shutter is not traveling all the way to form a light seal or the sequence of curtain movements during cocking are off, there may be gaps on the right side. A warped leading edge of a curtain may be catching on the frame and preventing proper motion.
Good luck!
09-24-2018, 07:08 PM   #8
Good luck!
Ok thanks for the tip
camera, check, comments, film, frame, leak, light, mx, seals, shutter
Light leak? ME Super Elteas Pentax Film SLR Discussion 8 07-28-2017 01:30 AM
Odd-shaped light leak hooverfocus Pentax Film SLR Discussion 6 05-05-2017 10:16 AM
Light leak on K1? mvon Troubleshooting and Beginner Help 8 04-07-2017 04:22 AM
Pentax 67 light leak or processing? Help!!!! addison11 Pentax Medium Format 16 03-17-2017 10:10 PM
Pentax 645 - light leak? Camera leak? dugrant153 Pentax Medium Format 1 07-05-2014 08:08 AM
All times are GMT -7. The time now is 08:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
