Originally posted by zzzxtreme . . . I understand that it is an apsc lens, but the vignette on full frame is slight ?
any help would be greatly appreciated
these links have info on what APS- C lenses do on a full frame camera
Pentax K-1 Review - Available Lenses | PentaxForums.com Reviews
__________________
Pentax K-1 Lens Compatibility Guide - Articles and Tips | PentaxForums.com
__________________________________
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
K mount lens dedicated to the APS-C form factor is used.
Image is taken full frame 36mm x 24mm.
Lens hood was removed.
And ideally, no filter is mounted.
The aperture used is specified (note that film cameras don't record EXIF...).
Sample image shows the entire field of view.
Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
DA 14mm F2.8: - (clawhammer)
DA 15mm F4.0: - (Zav)
DA 21mm F3.2 Limited: - (Boris Liberman)
DA 35mm F2.4 AL: +++ (aurele ;like FA35/2.0 and no vignetting) (frank)
DA 35mm F2.8 Limited Macro: 0 (ryno), + (@ 1.15 crop)
DA 40mm F2.8 Limited: +
DA* 55mm F1.4 SDM: +++ (aurele)
DA 70mm F2.4 Limited: +
D FA Macro 100mm F2.8 WR: +++ (officially specified FF by Pentax)
DA* 200mm F2.8 ED [IF] SDM: +++? (common belief, but is it true?)
DA* 300mm F4 ED [IF] SDM: ++ (officially rated "designed for FF" by Pentax patent US7715116)
SMC Pentax-DA zooms...
DA 10-17mm F3.5-4.5 Fish-Eye ED [IF]: FE, see #59, #61, #94. 10mm: heavy vignette / 14mm: almost no vignette / 17mm ++ (Reps, froeschle, Gooshin)
DA 12-24mm F4 ED AL [IF]: - (below 16mm, xitek.com), o (at 18mm, architorture), + (at 20mm, architorture), ++ (at 24mm, architorture)
DA 16-45mm F4: - (below 21mm, Nesster)
DA* 16-50mm F2.8 ED AL [IF] SDM: - (xitek.com)
DA 17-70mm F4 AL [IF] SDM: - (KjetilH)
DA 18-55mm F3.5-5.6 AL: - (at 18mm, Spongefingers; below 23mm, xitek.com)
DA 18-55mm F3.5-5.6 AL II: missing
DA 18-250mm F3.5-6.3 ED AL [IF]: - (xitek.com)
DA 50-200mm ED: -
DA* 50-135mm F2.8 ED [IF] SDM: - (elho_cid)
DA* 60-250mm F4 ED [IF] SDM: ++ (officially rated "designed for FF" by Pentax patent US7489452) probably good on full frame but evaluation still missing; the rating is +++ with a baffle modification, + without)
DA 55-300mm F4-5.8 ED: 0 (+, ++ at tele end, viking79)
Sigma K mount DC...
Sigma 18-200mm f/3.5-6.3 DC: -
Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
Read more at:
DA lenses on Full Frame: Test Shots thread - PentaxForums.com
