12-01-2018, 06:18 AM   #1
Pentax KM
Hi,
My camera is working fine when the back door is open, but when i close the door the rewind knob is advancing correctly then stops all together? So i opened up the door agin and it was all fine and advanced correctly... why is it not working when i close the door? please help!!
12-01-2018, 07:25 AM   #2
Iím not sure if this fully fits your description, but the rewind knob will sometimes move irregularly as a normal consequence of changing tension in the film spool.
As you advance the film, the tightly wound film in the canister may unwind a bit more internally. It wonít move outside of the spool, but it may move the knob and mean the rewind knob doesnít move the next time you wind the film.
If you really want to see if thatís the case, add a little tension on the knob with your fingers each time you wind the film and keep an eye open for movement between shots.
-Eric
12-01-2018, 08:11 AM   #3
twilhelm's Avatar
QuoteOriginally posted by TwoUptons Quote
-Eric
This is likely the issue. Also keep in mind that sometimes film may be wound tightly (especially with older or expired film), which can make advancing the film change tension at times.
When a fresh roll is put into the camera, the rewind lever may spin partially, then stop for a couple of frames before starting again as Eric pointed out. Shoot the entire roll and see what you get, then youíll know what is and isnít working.
12-01-2018, 12:31 PM   #4
pschlute's Avatar
QuoteOriginally posted by harrydaisy Quote
Sounds like poltergeist activity to me. Can you leave your house back door open when you go out shooting pictures ?
camera, door, pentax help, pentax km, pentax km 35mm, pentax km film, photography, troubleshooting
For Sale - Sold: (Lower price)Pentax KM film camera w/ K 55mm 1.8 lens 17dew Sold Items 6 08-09-2018 04:36 PM
Vintage pentax km series 35mm and lots of extras....need info.... Was heirloom louisiana337 Pentax Film SLR Discussion 11 01-16-2017 03:24 PM
Green Pentax Km is not coincidence, this is why.. HermanLee Pentax News and Rumors 41 04-08-2009 06:19 AM
All times are GMT -7. The time now is 11:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
