02-21-2019, 10:43 PM   #1
Pentax Super Program - No display on LCD, Shutter at same speed
Hi all,
I've a Pentax Super Program with the following symptoms with fresh batteries installed:
- No display of anything on LCD (both in finder and on camera top plate)
- LCD backlight works
- Shutter seems to fire at same speed - even for Bulb and 125
The finder is clean and it feels like a real nice camera.
Would appreciate any advise on the possible problem.
Thanks in advance!
HWH
02-21-2019, 11:23 PM   #2
Otis Memorial Pentaxian
Wind on several times. The display defaults to what you are seeing with a shutter speed of 1/125s for the first several frames until the counter gets to zero. It does this every time the back is opened.
I was wrong...expected is 1/1000s displayed in the LCD.
02-21-2019, 11:26 PM   #3
HWH
Thanks for the reply. I read abt that and wound on and went through maybe 20-30 shots. Same results. The LCD does not show anything either.
02-21-2019, 11:41 PM   #4
QuoteOriginally posted by HWH Quote
Sorry for the poor advice. I wrote before refreshing my memory from the manual or getting my Super Program from the closet.
Am I correct that you see nothing in the viewfinder or top LCD displays regardless of mode or settings? If so, I can't think of anything that is an obvious fix. The camera may be serviceable, but would require a competent technician to say for sure.
02-22-2019, 12:10 AM   #5
HWH
Not poor advice, still appreciate your effort to help. Seems the problem is no small issue. Can't justify sending it to the repairman as I already have an LX and a MX, and didn't pay more than US$20 for it.
02-22-2019, 12:10 AM   #6
In the normal working case, when the film is advanced/shutter is cocked, there will be a small black line in the upper right-hand corner of the LCD on the top of the camera. Are you seeing that?
A common failure case is a circuit board (?) failure, in which the internal and external displays do not turn on when you half-press the shutter release. But a workaround is to hold the silver button on the left-hand side of the lens mount -- this is for illuminating the viewfinder LCDs, but in this case it will also turn on the meter/displays. Does that do anything?
02-22-2019, 12:15 AM   #7
HWH
QuoteOriginally posted by leekil Quote
Thank you for your reply. Holding the button lights up the orange bulb, but still no display in the LCD.
02-22-2019, 10:51 AM   #8
gofour3's Avatar
It sounds like an electronic issue, similar thing happened with my Super A.
Try cleaning the battery contact part in the camera body and battery cap. If no luck Eric may be able to resurrect the camera.
Eric fixed mine with a cleaning and it's been working fine since then.
Phil.
02-23-2019, 05:10 AM   #9
HWH
QuoteOriginally posted by gofour3 Quote
Phil.
May I know what the charges from Eric? Thanks
02-23-2019, 10:55 AM   #10
Eric Hendrickson, Pentax Camera Repair
You send him the camera and he responds with an estimate. If too high for you, he sends the camera back. I have used Eric for repair and regular maintenance and his rates are quite reasonable.
02-23-2019, 11:47 AM   #11
gofour3's Avatar
Eric had done a CLA on my Super A within the year that it stopped working. He fixed the issue for free.
Phil.
camera, display, finder, lcd, pentax, pentax help, pentax super program, photography, program, program no display, shutter, troubleshooting
Super Program Wind Lever Stuck, LCD out, Shutter Closed Jake Schmidt Visitors' Center 4 06-19-2016 11:28 PM
Super Program LCD window TTL display shutter & aperture digital029art Pentax Film SLR Discussion 10 12-26-2015 05:37 PM
need help, super program got no view in LCD and viewfinder nbhuajie Pentax Film SLR Discussion 5 08-18-2011 09:15 PM
85mm vs. 50mm which is which (same subject, same aperture, same magnification) stevebrot Photographic Technique 50 07-01-2008 09:49 AM
All times are GMT -7. The time now is 08:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
