04-03-2019, 02:36 PM   #1
Pentax LX back wonít open
Hi everyone.
I recently acquired a LX, raised up the rewind lever but the camera back refuses to open like itís still latched. I know the LX used different seal material from earlier models so in general doesnít deteriorate causing the back to stick so am unsure what I am doing wrong or if itís a mechanical issue with the rewind lever not lifting the matching mechanism. All help would be greatly appreciated.
04-03-2019, 04:28 PM   #2
Wheatfield's Avatar
It’s probably stuck on the light seal. The mechanism is pretty robust. You might have to pry it open if it hasn’t been used for a while.
04-03-2019, 05:43 PM   #3
ChrisPlatt's Avatar
The film door is pressed from thin metal and might be slightly deformed (bent),
making it seal very tight. This may cause the latch mechanism to bind as well.
I have owned a couple of used 35mm cameras that seemed to have this problem.
I can't imagine how this could happen; I guess some owners aren't real careful.
Chris
04-04-2019, 11:24 AM   #4
Try squeezing the back against the body and releasing it while pulling up on the handle.
04-04-2019, 02:51 PM   #5
ne!
Interesting, I bought an LX from eBay about 6 weeks ago in great shape. The camera arrived and I couldn't open the film back either!
it turned out that someone had used super-glue to tack-down some of the leather cover near the door opening-- it had run into the seam and glued the door shut! Obviously I sent it back for a refund, and it explained why there where *no* photos of the film compartment in the original listing, my goodness.
lever, lx, pentax lx, rewind
K-1ii DNGs won't open in DxO Photolab Oakland Rob Pentax K-1 25 08-23-2018 08:57 AM
Pentax LX meter won't turn off / battery drain after CLA jayy Pentax Film SLR Discussion 5 05-02-2018 12:24 PM
Architecture I won, I won, I won Culture Post Your Photos! 12 11-13-2015 11:34 PM
IS any different between pentax LX dial back and data back? nihelaozi2 Pentax Film SLR Discussion 4 12-13-2012 11:58 PM
All times are GMT -7. The time now is 10:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
