Originally posted by stevebrot
I would not expect any groundbreaking improvements in dSLR tech that will directly improve the suitability to task for film copying.
Would increased megapixel resolution not make a difference, then? I know 'more megapixels isn't necessarily more better', (noise, etc...) but given that the DSLR processing engine seems (to me) to offer less noisy images for increasingly higher ISO it seems this is an improvement. I appreciate that copying a neg can only be as good as the resolution of the digital sensor doing the xopying, but surely a higher resolution sensor will eke more detail from the negative unti a point is reached where all neg detail has been got?
Unless that point has been reached now, of course. I find my Sony RX-100D copies my 6x6 negs to my satisfaction, and my ancient EOS 5D Mk: 1 copies 35mm negs as good as my prehistoric Acer Scanwit SCSI neg and slide copier when coupled to a 'traditional' slide-copier tube adapted for negs. I'd like to compare my 6x6 neg copies off the Sony with those off a drum-scanner, say.
I copy 6x6 negs with the Sony RX100 in a 'one-er' but am mindful that I could copy sections at a time and join them together, should I wish to do so.
