08-02-2019, 05:39 PM   #1
Foam for the Square Clip-on meter
Hello All,
I just purchased one of the square clip-on meters for my H1a.
I'll admit it's more because it looks cool than anything else...
I was torn between it and the round one, but I think this will work...
The seller has said they removed the foam because it was a disgusting mess (no great surprise)
I'd like to replace it so the meter sits better on the camera.
Does anyone have a photo of theirs in good shape from underneath?
And does anyone know what kind of foam it really is (or should be)?
The forum search was not very revealing from my phone this afternoon...
Thanks,
-Eric
08-02-2019, 06:12 PM   #2
ismaelg's Avatar
Hello,
The foam in mine is almost gone. It seems a bit denser and harder than regular foam. Not sure if that could be due to age.
Thanks,
SM-J510MN  Photo
08-02-2019, 07:09 PM   #3
If you have a pick and pluck foam insert on a case, you could use that foam to replace it.
08-02-2019, 08:54 PM   #4
arnold's Avatar
You can buy foam sheets with adhesive backing. Or you can use double sided tape, but leave the covering on one side. I used a piece of foam sheet cut to shape. I have several of these meters.
08-03-2019, 01:00 AM   #5
Dartmoor Dave's Avatar
Here's mine. I don't know how much foam there was in there originally, but as it is it fits snugly on the camera (my S1a) with no movement at all. The slightly worn bit is right where the meter sits on the angle at the top of the pentaprism.
08-03-2019, 06:13 AM   #6
My daughter has a ton of stick-on craft foam, so Iíll try that first.
It may be the first ever meter with orange foam
Thanks!
-Eric
08-03-2019, 06:13 AM   #7
Aki Asahi offers sheets of self-adhesive foam for light seals. I've purchased their seals and definitely can recommend them.
08-03-2019, 11:59 AM   #8
UncleVanya's Avatar
Cork may also work.
08-04-2019, 12:08 AM   #9
LensBeginner's Avatar
I'd try adhesive foam strips for stove tops.
Inexpensive and easy to find.
08-04-2019, 02:28 PM   #10
titrisol's Avatar
Location: In the most populated state... state of denial
Jon Goodman just posted back on this group, I wouldnt use anything else but his foam
clip on meter, clip-on, foam, h1a, meter, s1a, square
Pentax SV - Mirror bumper/damping foam? greyred2 Pentax Film SLR Discussion 17 10-09-2018 04:55 AM
Mirror box foam replacement lotech Pentax Film SLR Discussion 6 11-17-2017 04:50 AM
Battery for Asahi clip-on Exposure meter ripper2860 Troubleshooting and Beginner Help 5 04-18-2017 02:02 AM
Abstract Circle, circle, square, square LensBeginner Post Your Photos! 2 11-19-2014 05:44 PM
All times are GMT -7. The time now is 05:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
