Originally posted by OldChE
How do you like using the AF240T? That is one flash I don't have, I was wondering if I should get it. I do have the AF160SA, AF200T, AF280T, AF360FGZ, and my latest addition is the very neat Pentax Autorobo, so I don't know if another flash unit would really add anything to what I could do with those.
It's the AF240FT - one of the original auto focus flashguns (not helped by all Pentax guns starting with AF...). It provides an AF illuminator and basic TTL flash for the AF SLRs that support it (GN24m, fixed head). With the SFXn I used it in combo with the built in flash for more output. It also supports rear (2nd) curtain sync. It only offers full TTL or manual (full or quarter power) flash and does not have it's own sensor.
It doesn't provide any of the current Pentax PTTL modes and can only be used as a manual flash on current Pentax DSLRs.
I use it today in two ways:
1) It's a safe gun to use in manual on a DSLR, either manual flash or in quarter power as fill or to trigger other guns via optical slaves.
2) To provide an AF illuminator or rear curtain sync for my 645D (I don't use flash enough to justify buying an expensive current flash). You can set the gun to AF illuminator only (i.e. no flash).
