Found this little nice camera at a fleamarket, the owner said it is dead, lightmeter didn't work and it didn't wind..
sounds familiar, right?
well, I took it nonetheless for 15 bucks, thats a non brainer. I thought I could use it for part as I already have a working chrome ME super, I planned to switch top and bottom cover from that black one with my chrome ones..
at home I saw the reason why the lightmeter 'was dead'..the mirror was stuck in the upward position. Also the winder didn't catch.
I didn't want to damage it, so I didin't force the mirror to come down, I had the feel that it was a good camera, not dead.
instead I screw off the bottom plate and watched the winding mechanism closely. The is a metal tounge that, when I carefully forced back, the cycle of the winding finally completed, the shutter popped up, and the mirror came down. So, it worked actually!
The lightmeter worked without a problem, and the screen was in top condition, better than on my chrome ME Super, surprise!
Ok, one problem solved. I noticed after the 10th time I used the winder it actually did crank and I was able to release the shutter.
I just went on and cranked and cranked, carefully and slowly, but firmly, at least 100 times..
then it worked after every 5th time..then every second time..then every time..after I slowly cranked it half way, then to the end.
now it works every time.
I shot a test roll yesterday, but AFTER 36 shots I realized the little bottom rewind knob down under was IN! no wonder.
so almost 30 double exposures!! I just forgot after the assembly to reattach the little rewind knob properly..now it's fine.
I attached a multi exposure .
very interesting abstract art..
I love this camera..I have a MX,too, but the manual buttons on the super are much better than the shutter time dial, I think I will sell my MX..
so, if you have the same problem, take your time, and try it..maybe it work for your ME super, too..
