01-21-2019, 02:49 AM - 1 Like   #106
Not a Number's Avatar
QuoteOriginally posted by Jean Poitiers Quote
Resurrection of an old thread ... but still a useful one.
I have just opened the bottom of a MZ-5n that I recently acquired to get an idea of the task involved. I have figured out where the motor is, etc. ... and it's a shame that it's so deep in the body. I removed the right-side of the front in order to access a screw which held the gear plate. I can move the mirror manually by hand spinning the gears next the the motor.
I hesitate a bit here ... has anyone recently done still successfully and are the brass gear motors still available? Cheers, J
See post #52
QuoteOriginally posted by 45 Mike Quote
I just ordered the gears, that are still available from HERE:
Mikroantriebe KK Produkcja Zahnrad, Schnecken und Car System Onlineshop - Zahnrad / Trieb M0.25 / 13 Zähne
If you order you must change the drill/hole diameter to 1.5 mm
Change the width to 2.0 mm
and the material to brass
with shipping, for three of these gears, the cost was $20.93 USD
On the 4th page of this thread is the procedure that works for replacing just the gear, without the complete removal of the motor.
I will report back if/when I manage the repair on my ZX-M and ZX-5
Eric would not repair my ZX-M as he cannot get the correct pentax parts. I wonder if he might be willing to order these gears and just replace the gears.
01-21-2019, 03:38 AM   #107
Jean Poitiers's Avatar
See post #52
Thanks !
I will check this out.
01-21-2019, 06:49 PM - 1 Like   #108
ChrisPlatt's Avatar
Holy cow, look at all those plastic gears!
Chris
01-21-2019, 10:36 PM - 1 Like   #109
I suggest you get a pinion gear puller if you can find one that handles a 1.5mm shaft and can get close enough to the motor without removing it.
Premium Steel Universal Motor Pinion Gear Puller Remover for RC Motors Accessory | eBay
Shaft sizes are not listed for the above. I suggest contacting the seller. Otherwise it might do the trick.
03-18-2019, 12:35 PM   #110
I don't want to brutal, but unless you are very good at taking small complex things apart and putting them back together I would go find a different camera. If you are determined I have three of the Polish gears I can send you for just the postage. These cameras particularly hate sitting unused, so a mint one that has been sitting in a drawer for 20 years will get through anything between a couple of frames and half-a- dozen films because it packs up.
I've got a drawer full of the flippin' things.
07-15-2019, 06:28 PM   #111
QuoteOriginally posted by redbirdpete Quote
Hello,
My ZX-7 Mirror motor just died yesterday.
Please send me those gears if you still have it, and just let me know how much is the postage.
Thanks in advance,
Momo
01-28-2020, 01:58 AM   #112
It may be of interest to others struggling with this camera that the full service manual for the MZ-5 (which is very similar to the MZ-5n) is available for free from Electrotanya.com. Also, I found that the problem with a stuck mirror with my MZ-5n was not the motor but with the shutter switch. This would respond to the first light touch position but would not make contact when fully depressed. I opened the switch and found the problem was corrosion on the moving flexible contact. After cleaning the switch my mirror now works but the shutter curtains fail to open ! Incidentally the service manual says that the mirror motor should be tested on 1.5V but the motor is actually a 5V motor and will not work on 1.5v.
Incidentally, I had a similar problem with a Nikon F65 but with that camera the problem was that the lubricant inside the shutter switch had solidified into a jell making the switch inoperative.
10-04-2020, 12:51 AM   #113
Location: Adelaide, South Australia: Don't tell anyone how good it is, please.
I scored and Ebay MZ50, was after the lense. But it still has film in it, so I figure why not? I got some batteries for it, put them in, yep, lcd works, buttons appear to work. Cool.
I then chuck the batteries into my dads MZ50.... display lights up... but the mirror is up.. I can gently pull it down, but it wont lock down: I put a lens on it, it tries to focus etc... seems everything is ok, but the mirror:
Is this the dreaded mirror gear failure? Is there anything else I need to check to confim this? TIA
bit, body, brass, change, eric hendrickson, gears, mirror, mm, mz5n, plastic, repair, service, wonder, zx-m
Looking for service manual: MZ-5n and MZ-50 CGJung Pentax Film SLR Discussion 24 04-20-2011 12:01 PM
ME Super Service Manual pandarocket Pentax Film SLR Discussion 20 03-17-2010 12:32 PM
K100D Service Manual? Spag Pentax DSLR Discussion 4 12-12-2009 04:17 PM
Need service manual for a PZ-1p. Bob 256 Pentax Film SLR Discussion 6 07-17-2008 07:47 AM
MZ-S Service Manual?! time-snaps Pentax Film SLR Discussion 1 02-14-2008 05:25 PM
All times are GMT -7. The time now is 05:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
