10-16-2019, 04:27 PM   #16
monochrome's Avatar
I have a late LX - apparently version 3 - that has the roller inside the film door. It has 2 short, stainless-looking rollers approximately where the sprocket holes would be, mounted on a black metal shaft or axle that runs nearly the full height/width of the film door.
10-16-2019, 04:59 PM   #17
Otis Memorial Pentaxian
Two!? Did you write TWO!?
Clearly, there is inequity in LX land with some completely lacking!
Stev
10-16-2019, 05:31 PM   #18
Stev
Maybe he took an extra
-Eric
10-16-2019, 06:04 PM   #19
monochrome's Avatar
Stev
I did write two, but after a very close inspection there is one single, shaped stainless shaft. By shaped I mean that the “two” rollers are formed into ends of the shaft itself just as the OP’s photo. My initial impression that the roller had a black axle through two cylinders was a trick of poor lighting.
Eric CLA’ed my camera in 2014. The seller represented it as a 1999 model.
IPhone 6 Plus  Photo
10-16-2019, 06:10 PM   #20
It does look like two.
Reflections are annoying
-Eric
10-16-2019, 06:11 PM   #21
That is an interesting design.
10-16-2019, 06:28 PM   #22
monochrome's Avatar
QuoteOriginally posted by TwoUptons Quote
-Eric
Yes - I had looked at some of my other cameras just to see what was what and the LX roller is unique.
No Roller: MX, MESUPER, SuperPROGRAM, MZ-S.
Roller - straight shaft, center roller <width of the pressure plate (film width?), with narrow end ‘pins’ as in a watchband shaft: K1000 and SE (pictured), KX, K2, K2DMD, SP-F, ESll (I didn’t look st the AP, K, H2, S, S3, SV or Asahiflexes since they are stored).
Roller - shaped as photo above: LX
I suppose the outliers are the M cameras that don’t have a film roller.
IPhone 6 Plus  Photo
10-17-2019, 02:52 AM   #23
Baard-Einar's Avatar
I have a roller in my LX which I bought new in 1982. I think that LX is version 1. Then I have two other LX'es. One is a frankenstein-version, mix of two cameras to get one working copy. One has a roller and one is without the roller, not sure which back door belings to which serial number any more.. So not easy to know exactly when that roller appeared without doing deeper research.
10-17-2019, 09:22 PM   #24
I do like this design of roller . It leave the emulsion less likely to be scratched
lx
Digital backs for the 645 Siebig Visitors' Center 9 11-30-2022 09:05 PM
Camera project with M42 mount and interchangeable digital and film backs Tas General Photography 5 01-08-2018 08:02 AM
ZX-L (MZ-6) and ZX-7 (MZ-7) backs the same? TwoUptons Film SLRs and Compact Film Cameras 3 12-29-2017 11:32 AM
LX backs womble Film SLRs and Compact Film Cameras 2 08-03-2012 03:01 PM
All times are GMT -7. The time now is 12:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
