10-21-2019, 02:43 PM   #1
Anyone use "Photoplug" shutter tester?
I know there are a couple of ways of checking your shutter speed using a CRT TV or a record turntable.... admittedly I've not actually tried those. Looking online at other methods I noticed a device called "Photoplug" which seems to be a small light sensor which plugs into your smartphone headphone jack. Details here:- Filmomat ? PhotoPlug..PhotoPlug
I was just wondering if anyone had tried this and if it was accurate?
10-21-2019, 06:06 PM   #2
This will work only for cameras where you can access the area behind the shutter (as they say in their material: "Open/Remove the camera back")
It will not work for most digital cameras. For that, you need something like my LED flasher: True Shutter Speeds compared to Nominal Shutter Speeds - Actual Measurements - PentaxForums.com
If you are handy with circuitry, I'd be glad to share my design.
10-21-2019, 06:42 PM   #3
boriscleto's Avatar
QuoteOriginally posted by AstroDave Quote
Well this is posted in the Film SLR forum...
10-21-2019, 07:03 PM   #4
QuoteOriginally posted by boriscleto Quote
My bad!!
10-22-2019, 07:06 AM   #5
photoptimist's Avatar
I've not ever used it but it looks like a solid concept.
The only minor accuracy issue would be caused by the sampling rate of your particular phone's microphone circuits. Some phones only sample at 8kHz which is adequate for telephone calls but would lead to Photoplug inaccuracies for shutter speeds faster than 1/1000.
10-22-2019, 10:22 AM   #6
I'm not an electronics or mobile phone expert but would a device connected to the headphone jack use the microphone circuit?
Regarding using this device with the film back open, I think it will only work with older mechanical SLR's like my ME Super, MX and K1000. It won't work with my modernish Canon EOS 3 because the shutter doesn't operate normally with the back open.
10-22-2019, 10:58 AM - 2 Likes   #7
QuoteOriginally posted by Vendee Quote
The jack on a smartphone includes an extra contact for the microphone on a headset. The Photoplug is using that microphone connection to send a signal into the phone. The app then samples the electronic signal coming through the jack as if it were audio and interprets the waveform to detect when the shutter opened and when it closed.
The microphone circuit in a smartphone can be used to measure any time varying signal within the frequency and voltage limits of the circuit.
10-22-2019, 02:30 PM   #8
Thanks for the explanation............ always learning
Edit. And just googled my phone and it appears to sample at 48kHz so should be fine.
10-22-2019, 02:50 PM - 1 Like   #9
Depending on the camera, you may be able to fool it.
With some cameras, the door pushes a switch in the body to let it know it’s closed. Jamming something gently into the hole will let the camera operate normally.
Some cameras need the film to wind, so you have to jam the switch and then spin the film sprocket between frames.
-Eric
10-23-2019, 12:52 AM   #10
QuoteOriginally posted by TwoUptons Quote
-Eric
Wow, that worked thanks. I had notice 3 electrical contacts inside the back door which mated up with the body when closed and I had assumed that these needed to be made to allow the shutter to fire but it seems that these are for the operation of the controls. prodding something in the door catch mechanism allowed the shutter to fire normally with the back open.
10-30-2019, 08:36 PM   #11
disconnekt's Avatar
I think I've seen this before (or something very similar) a few months back
shutter
AA and AAA Rechargeable Battery Tester C_Jones Pentax Camera and Field Accessories 16 12-07-2016 06:51 PM
K1 Beta Tester ansering questions on Photography Reddit interested_observer Pentax K-1 3 02-18-2016 09:30 AM
Asahi Shutter Tester jatrax Pentax Price Watch 3 08-20-2014 05:42 PM
Tester claims New Sony A77 is top notch! JohnBee Non-Pentax Cameras: Canon, Nikon, etc. 9 06-02-2011 09:38 AM
All times are GMT -7. The time now is 01:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
