Having an operational and recently CLA'ed Spotmatic F in the pool has allowed me some time with its signature feature, that being open-aperture metering with S-M-C/SMC Takumar lenses with stop-down meter support for other lenses. The good news is that the open-aperture feature is robust and effectively allows the Spotmatic F to function similar to the later KM when matched with supporting lenses.
1
The mixed news is that backward support with stop-down metering is not universal. I had seen cryptic comments hinting at less-than-broad backward compatibility in various reviews on the SP F, ES, and ESII, but was able to qualify the behavior this last week with a newly CLA'ed body in hand. In summary:
Asahi Super Takumar- Full and transparent stop-down metering compatibility as if the lens were being used on prior model metered Spotmatic bodies
- Uncomplicated automatic aperture automation
- Uncomplicated use of A/M switch
Non-coupled Bellows and Extension Tubes (Asahi and Third-Party)- Full and transparent stop-down metering compatibility as if it were being used on prior model metered Spotmatic bodies
Third-Party Lenses/Accessories- Mixed compatibility with some lens being full and transparently compatible and others carrying a risk of severe damage to the camera's open-aperture linkage mechanism.
The severity of this risk cannot be overstated. - Details in discussion below.
What does not work and why it matters
The short answer is that using a non-S-M-C/SMC lens has two requirements. The first is that the lens rear clears the couplings used for open-aperture metering. The second is that the aperture actuator pin (if present) be capable of passing through a narrow slot in the aperture ring position coupler without bottoming out or binding. Failure of the first is obvious in its implications (crunch); failure of the second, somewhat less so until it happens.
For most lens with an aperture actuator pin, the pin is challenged by the "slot" well before the lens is fully engaged in the mount. If the pin is too fat, too deep, or aligned too far inboard/outboard, it will catch on the aperture ring position coupler and swing it to the full extent of its travel at which point there will be an abrupt contest of strength between lens and coupler with potential for damage to both; at least this is the case unless the problem is noticed by the user and the attempt to mount aborted.
For cases where the pin is well-aligned, but too deep, it is tempting to attempt a mount with with the A/M switch in the M position using gravity as an assist to keep it in a retracted position through several revolutions until the lens is full seated. While there is potential for success, the larger risk is potential to not be able to clear the coupler for unmount. In such case, the lens will be stuck on the camera with few obvious options for freedom.
To Detect Incompatibility
Use these screening tests at your own risk. I make no guarantee of safety or effectiveness.
First screen for the second issue, actuator pin interference. To do so,
slowly screw the lens on to the mount (A/M switch in the "A" position) paying careful attention to any resistance or feeling of scraping. Full interference is expressed by the pin moving the coupler against its tensioning spring. This last is very obvious when it happens and is a clear signal to back off and never attempt to mount that lens again on that camera.
For lenses with outsized rear elements, most should not present an issue if they have adequate clearance to work with Spotmatic models having the traditional mount. This may be assessed on those bodies by examination from the rear with the shutter locked open in "B" mode (use a locking cable release) and the lens with the A/M switch in the M position and the focus at closest position. That should allow the lens to fully seat onto the mount flange with the lens rear well away from the mirror and actuator flipper. Slowly move the focus ring to infinity while confirming clearance.
Doing the same as above is possible with the open-aperture mount, but greater care should be taken at all steps taking note that interference with the aperture ring position coupler may happen well in advance of the lens actually approaching full engagement with the mount face. Because of that interference, it is best to leave the A/M switch in the A position until almost fully seated.
If the above tests are not clear, take the safe route and only use Asahi/S-M-C/SMC Takumar lenses on your camera. Compatible Third-Party Lenses From My Shelf
These are provided for information only and are not indication of suitability of your lenses on your camera.
- Vivitar 28mm f/2.5, ser#22440767
- Vivitar 135mm f/2.8, ser#2813776
- Vivitar 200mm f/3.5, ser#28401094
- MMZ Helios 44-3 58mm f/2.0 (pre-set)
- Tamron Adaptall-2 M42 adapter (labeled "for Pentax")
- Vivitar Automatic Tele Converter 2X-1 (M42)
Incompatible Third-Party Lenses from My Shelf
While not necessarily an indication of what your results might be, my intuition is that if you have one of these, it probably won't work.
- Auto Rikenon 50mm f/1.7 (Tomioka)
- Auto Rikenon 55mm f/1.4 (Tomioka)
- Auto Mamiya/Sekor 55/1.8 (black finish, ribbed metal grip, black snout with fine chrome edge)
- KMZ Helios 44M 58mm f/2.0
1 Supporting lenses for open-aperture metering on the Spotmatic F, ES, and ESII include most Asahi S-M-C and SMC Takumars as well as Tamron lenses adapted with that brand's ES adapter.
