11-19-2019, 01:19 PM   #1
Hello and a bit of help please
Hi,
My name is Edward. I'm new around here. I always loved Pentax film cameras and always looked for help and information on this forum. Today I need some help as I could't find any answers for my problem.
I need a pressure plate for my Pentax MX. Can I use one from a Pentax Spotmatic? I know they are a bit diffrent but they fit on the MX. Another solution would be a pressure plate from a Pentax ME. They look the same in pictures but I'm not sure as I don't own one.
Thank you!
11-19-2019, 01:53 PM   #2
MarkJerling's Avatar
Welcome to the forum Edward.
I can't answer your query, but, no doubt, someone will!
11-19-2019, 02:18 PM - 2 Likes   #3
ME Pressure plate
Hello Edward,
I just compared the pressure plates of ME and Spotmatic SP1000
Spotmatic plate is 3,8 cm x 5,5 cm
ME plate is 3,8 x 6 cm.
Thickness of both plates is 1mm.
I believe that the 2 plates are interchangable as fixing holes distance is the same.
The film guides of the 2 cameras are both 6 cm long.
Maybe the longer plate installed in the ME is an improvement to achieve better film guidance.
11-19-2019, 04:58 PM - 1 Like   #4
I have a broken MG. Its plate is approximately 61mm x 38mm. I assume it is the same plate used by the ME.
EDIT: Measured with a digital caliper: 63.12mm x 37.82mm, and the post spacing is 54mm x 27mm center to center.
11-19-2019, 06:18 PM - 1 Like   #5
The MX and ME Super plates I have are slightly different sizes, and the Spotmatic is a different size and shape...
Doesn’t mean it won’t work... just means it might not
The ME Super is pretty close... I don't know if the ME and the ME Super are the same, but I gave away my ME when it broke...
Here's the ME Super (left) and the MX (right). MX door is longer (who knew?) but it looks like the pressure plate attachment is the same between them.
And the Spotmatic (left) and the MX (right). Very different door and pressure plate...
This Spotmatic is just a SP. And that MG plate looks just like the ME Super one...
-Eric
11-20-2019, 05:05 PM   #6
Thank you all for your replies.
I've ordered a ME pressure plate from ebay and I will use that. For now I'm using one from a Spotmatic and it looks like it's keeping the film flat. I don't know what can go wrong but time will tell.
In the future I will buy a broken MX for parts but for now I think it works like this.
bit, film, help, mx, pentax, pentaxmx, plate, pressure, problem
Quick bit of help please (K-1 custom settings) alamo5000 Troubleshooting and Beginner Help 7 07-05-2018 03:17 AM
Raw: 14 bit vs 12 bit Wingincamera Pentax DSLR Discussion 18 11-03-2012 12:37 PM
Oh man, please please please help.... deckroid Photographic Technique 8 07-01-2011 09:08 AM
24 bit or 48 bit scanning photolady95 Digital Processing, Software, and Printing 3 05-29-2009 08:14 AM
12-bit, 14-bit and 48-bit capture Clarkey Troubleshooting and Beginner Help 1 02-19-2009 09:16 PM
All times are GMT -7. The time now is 07:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
