Show Printable Version 10 Likes Search this Thread
11-26-2019, 04:56 PM - 3 Likes   #1
ismaelg's Avatar
New adventure: KX restoration?
Hello,
Yes, another adventure from one of those eBay gambles. A non working paperweight KX for $25 including shipping. Not exactly the deal of a lifetime, but what can go wrong? If I can't fix it I can always send to Eric to fix or cleanup and simply display.
The description simply said non-working. But the pictures show a really tired and possibly abused girl. I had to rescue her!
Mirror was stuck in the up position. Camera was frozen stuck. Could not advance, fire, nothing.
Looks complete but it seems it hasn't been cleaned in like... forever
(mirror is already down, but more on that later)
Yikes!
Lawson was here. Ouch! One of the dirtiest viewfinders I've ever seen!
At least the inside looks decent
Stay tuned! I have no idea where this train wreck is going....
Thanks,
11-26-2019, 05:21 PM   #2
Aaron28's Avatar
sweet! good luck!
11-26-2019, 05:37 PM - 1 Like   #3
ismaelg's Avatar
Hello,
So here we go...
Removed the bottom plate to find a set of corroded batteries. Fortunately the corrosion hit the battery holder, not the contact. Still trying to get it unstuck. Some WD-40 was not enough. Keep trying.
The reason why it is stuck is the mirror catch lever is frozen.
Cleaned it a bit and forced it back and forth. After a while I put a drop of light machine oil and kept exercising it. After about an hour it started to react. That was promising. Left it overnight and it is now working! I'm pretty sure it will get stuck again every once in a while but at least it is firing now and all speeds sound ok.
Thanks,
Thanks,
11-26-2019, 09:34 PM - 1 Like   #4
calsan's Avatar
..makes mental note to never lend equipment to anyone named Lawson...
11-26-2019, 09:44 PM   #5
Eyewanders's Avatar
Good lord. If you do send that on to Eric and he charges his normal CLA for that era, it'll be the deal of a they century. I can smell the musty from here.
11-26-2019, 09:53 PM   #6
Not a Number's Avatar
WD-40 isn't a penetrating oil Try something like PB B'laster and leave it overnight or longer.
11-27-2019, 06:13 AM - 1 Like   #7
titrisol's Avatar
Location: In the most populated state... state of denial
ismael, the KX is a tank, and despite all the abuse it will work
For the battery a drop of vinegar will help dissolving the corrosion
after you appl vinegar a few times them the penetrating oil will work fine
This one uses a SR44/357 battery
11-27-2019, 08:11 AM - 1 Like   #8
Another vote for PB Blaster after the vinegar or better yet CLR (calcium, lime and rust remover), a much stronger acid compound. If you already put the oil on, the vinegar etc. won't get in. The little triangle you see in that one picture is the beginning of prism desilvering which can't be repaired.
11-29-2019, 09:46 PM - 1 Like   #9
ismaelg's Avatar
Update:
Exercised it at all speeds and everything seems to be working fine. Only once, at 1s shutter speed (lowest speed before Bulb) it did not complete the cycle. By moving the shutter speed dial it completed. But ever since it's been ok.
Here is a quick and dirty video. Pardon the crickets, it was recorded at midnight
Unfortunately I'm heading for a work trip out of the country so I won't be able to play with it in a few weeks.
Still fighting the battery holder, to eventually test if the meter works.
Thanks,
11-30-2019, 11:07 AM   #10
Eyewanders's Avatar
Update:
everything is proceeding according to plan....
12-01-2019, 09:19 AM   #11
ismaelg's Avatar
WOHOO!!
The battery holder put up a phenomenal fight! It defeated every single product and technique I threw at it. I was already considering "destructive techniques". Got a can of PB Blaster as suggested. I used probably half a can over a day. Did not budge until last night at around 9PM it broke free!!!!!
And here is the best part: The holder was very corroded. I was able to remove the plastic guides and since it was shot anyways, I went to town with the Dremel and a wire wheel. Tested for continuity and it was promising. Mounted back to the base plate and tested again for continuity. Pass. Assembled it back, put two batteries and.....
THE METER WORKS!
Not sure how accurate but that test will have to wait at least a week as I'm heading out of town.
I will eventually work on the cosmetic part of it.
I'M HAPPY!
Thanks,
12-01-2019, 03:35 PM   #12
Wow, that's testimony to how durable these things are. "Takes a licking and keeps on ticking"
Good work.
---------- Post added 12-01-19 at 04:35 PM ----------
Good work.
12-17-2019, 02:14 AM   #13
e_nogueras's Avatar
Patience is indeed your virtue my friend.
12-17-2019, 03:23 AM   #14
nickthetasmaniac's Avatar
Holy moly, as they say!
Very impressive salvage effort
12-17-2019, 08:12 AM   #15
ismaelg's Avatar
Thanks guys! Unfortunately I have been out of the country on business travel so no progress in about 2 weeks. Can't wait to get on it again!
Thanks,
adventure, kx, mirror
Why stop motion car restoration is Youtube the hard way interested_observer Photographic Technique 6 10-30-2019 10:54 AM
Lens body restoration. Prince Harbinger Pentax SLR Lens Discussion 7 03-11-2019 04:56 AM
K1000 restoration video johnhilvert Film SLRs and Compact Film Cameras 10 11-22-2016 04:30 AM
Restoration of rubber rings of a 500mm series K cyberjunkie Pentax SLR Lens Discussion 3 02-22-2016 07:33 PM
Question Camera Restoration Info ... Jean Poitiers Site Suggestions and Help 4 11-19-2011 07:35 AM
All times are GMT -7. The time now is 01:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
