10-22-2008, 08:37 PM   #1
sharko's Avatar
k1000 light meter not working properly
The light meter on my k1000 seems to be acting flaky. It started happening all of a sudden as it was working fine before but what happens now is the aperture ring on the lens (any lens) does not move the light meter. It seems to respond well to changing the shutter speed and moving the camera around the scene between light and dark areas, but changing the aperture does nothing at all. Do you guys think it needs to get sent in for repairs or is there something I can try to check?
10-23-2008, 02:48 AM   #2
Maybe the battery simply died.
To check the battery, set the ASA dial to 100 and the shutter to B. The needle should "peg" at + and stay there. If it doesn't, the battery needs replaced.
10-23-2008, 06:54 AM   #3
Wheatfield's Avatar
If the battery is good, check the aperture follower lever to make sure it is engaging the lens, and perhaps exercise it a bit to clean any corrosion off the aperture follwer resistor.
10-23-2008, 08:47 AM   #4
Banned
this is my advice as well. seems the meter still works as you say it responds to shutter speed changes.
10-23-2008, 06:16 PM   #5
I had the exact same problem with my KX. Try cleaning the battery chamber, and the contact points. My lightmeter would flake out every now and again (usually when I needed it to work), but a quick brush with a small wire brush and some alcohol moistened q-tips fixed it very nicely.
10-23-2008, 09:57 PM   #6
sharko's Avatar
Hmmm there seems to be a missing link somewhere. I've tried three different batteries, cleaning the battery chamber, and multiple lenses to rule out a bad aperture ring. How can I make sure the aperture lever in the camera is properly engaging with the lens?
Thanks for the help so far.
p.s.
Forgot to mention that if I set the shutter to "B" and the ASA to 100, the light meter shoots all the way up. Problem?
10-24-2008, 02:27 AM   #7
QuoteOriginally posted by sharko Quote
p.s.
Nope. That's what it should do.
If it started acting up "all of a sudden" I doubt it's the aperture following resistor becoming corroded... that doesn't just happen. My KX was that way when I got it, but I strongly suspect that it was stored in a cardboard box in someone's attic or basement for at least twenty years....
10-25-2008, 09:04 PM   #8
p.s.
When you leave the lens off of the camera, and manually move the aperature sensing lever up and down, does the meter change accordingly?
Before I sold you this camera, I did mount a couple of lenses on it, and it was working properly. Even the original owner (whom I purchased the camera as part of a lens deal) said it was working a-ok.
10-26-2008, 10:03 AM   #9
sharko's Avatar
Seems like something inside the camera is wrong. I don't know much about film SLR's but yeah if I move the aperture lever up and down it doesn't change anything. I thought it was moving a little at first but that was just my finger moving in and out of the view, lol. So I grabbed a pen and moved it and the light meter stayed stationary. What would need to be replaced at this point?
10-26-2008, 10:38 AM   #10
At this point I'd suggest sending it to Eric over at pentaxs.com. He's the best Pentax repair man there is. For about $65 total he'll make your K1000 like new.
10-26-2008, 11:58 AM   #11
sharko's Avatar
Sounds like a plan. Thanks!
aperture, k1000, k1000 light meter, lens, light, meter
k1000 - light meter stuck on + 2ipper Pentax Film SLR Discussion 12 01-04-2017 07:10 AM
K1000 exposure meter does not register in low light Capslock118 Pentax Film SLR Discussion 15 10-29-2010 08:29 AM
MX - B not working properly pontusadefjord Pentax Film SLR Discussion 3 09-13-2010 11:01 AM
Asahi SPII My Light Meter Isn't Working. Cameron030293 Pentax Film SLR Discussion 7 10-13-2009 06:46 AM
Asahi Pentax ME, Light Meter not Working MacetheAce Photographic Technique 12 10-04-2008 02:31 PM
All times are GMT -7. The time now is 11:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
