01-11-2020, 01:01 PM   #1
Pentax MX advance lever is stuck
I have a pentax MX camera, the wind/advance lever won't advance. I tried opening the bottom to see what the problem was, but everything was fine. I think the prob is in the top?? Can you help me? Give me some ideas or share some photos
01-11-2020, 02:15 PM   #2
Not a Number's Avatar
Is there film in the camera? If you wind to the end of the spool the advance can get stuck part way. Rewind the film.
01-11-2020, 06:36 PM   #3
I’ve done that before. Completely freaked me out...
-Eric
01-12-2020, 08:44 AM   #4
There’s no film in the camera.
01-18-2020, 01:46 AM   #5
I just fixed an Mx with the same problem today!
If your camera is cocked, with the orange indicator at the top showing, it could be possible the mirror mechanism wasn’t engaged.
You should do what this guy says on post #4 to get a better look: Pentax MX stuck shutter - PentaxForums.com
Take a picture and note how everything looks for reassembly, but it’s pretty easy. after removing the two screws, A pair of tweezers may help maneuver the low speed assembly out, and later back into position.
the screw head that MysteryOnion kindly pointed out, should be pushed up towards the front of the camera body when it is in the cocked position. If it is positioned towards back, carefully take a screwdriver to slide the spring loaded screw head towards the front of the camera. You will feel it catch. Then, try pressing the shutter button and if the camera fires, check if it will wind again.
Let us know how it goes! I can provide pictures if needed
3 Days Ago   #6
QuoteOriginally posted by Estey Quote
Hi Estey
Thanks for this explanation! Restoring does not work right for me? Could you possibly provide your photos?
Thanks in advance! Pablo
advance, lever, mx, mx advance lever, pentax, pentax mx advance
Pentax auto 110 super slr - film advance lever is stuck need advice teamrums Visitors' Center 3 01-09-2020 04:57 PM
Plastic piece for advance lever on an MX John Brown Pentax Film SLR Discussion 6 01-23-2019 08:41 AM
Advance lever stuck? KX lejordan Pentax Film SLR Discussion 6 07-05-2017 12:06 PM
All times are GMT -7. The time now is 08:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
