Originally posted by aslyfox
it appears from photos that original style cases for the Pentax ME Super and similar SLR are not practical
it appears that the case must be removed in order to load film
and if a winder is mounted to the camera body, the case cannot fit
can anyone confirm that for me
I'm curious because I just got a ME Super and Winder ( II ) from a forum member in order to celebrate my birthday ( my dad used one back in the day )
I like using ever-ready cases, despite the common opinion that they are not worthwhile. I got a Pentax Spotmatic in 1970 and have used it ever since, nearly always in its ever-ready case (which is real leather). The case has held up very well over 50 years, and I credit the case for protecting the camera very well over those years as well. I don't have a problem keeping the top part of the case latched onto the bottom part. When I want to take a picture, you just unsnap the top part and rotate it forward so it hangs below the camera, and you can use the camera as you need to take the shot. Then you fold it back over the camera and snap it shut if you are done. Two things though: first, this all works well if you are walking around outside taking a picture or two here or there - as someone noted, folks who grew up in the film era often tooks days or weeks to burn through 36 exposures. At times when I was shooting a lot at one time, or didn't need the extra protection, I'd remove the top part of the case (and have to stow it somewhere), and when I needed to work with a tripod I'd remove the case entirely. Second, this works well if you mostly use just the normal lens, or a wide angle prime. The lens has to fit well within the case. They did make "small, medium, long" versions of these cases, but I've always thought the large cases that would handle a zoom just seemed too much. Back when I first learned photography most people just used primes, and quite often a normal or wide angle for most shots, so this wasn't much of a problem.
I agree with other posters here that the official Pentax cases in the "M" era were made of materials that, over the years, have not proven to be durable. The materials starts to get soft, sticky, and then to flake off. You are much better off buying that aftermarket case sold by Pacific Rim (and other vendors on ebay). I bought one, and I can attest that it is still in good condition (many are "new old stock"), it fits as it should, and the materials used seem just fine. I got mine to use on a Pentax Super Program, which uses the same size case as the ME Super.
Richard.
