The ES-2 (
LINK) is made to work with any of three models of Nikon macro lenses with the lens at minimum focus distance. One of those, the AF-S DX Micro NIKKOR 40mm f/2.8 G is preferred for use with APS-C cameras (the other two being FX and presenting a cropped image). To make the ES-2 work, the lens requirements would be:
- Magnification (1:1.5) to fit the image of the negative to the APS-C frame when fitted natively to the 52mm thread on the ES-2
- Attaining 1:1.5 magnification when used with either of the two 62mm supplied adapters
I think this may be difficult, though the device does have a bit of play to allow for adjusting framing.
Note: I had to edit significantly as I learned more about the ES-2.
