Thanks Steve, I can't see a tolerance range quoted only millisecond equivalents, unless I can't see the wood for the trees. I have a generic chart which gives a range e.g. 1/1000 should be acceptable between 0.70 and 1.30 milliseconds, I may use that if getting spot on is impossible.
I'm using a Phochron XA tester with the twin curtain sensor as it gives 1st and 2nd curtain readings. This is the link
Phochron XA- hand held shutter evaluation
It works well and you can self check the calibration too. It will work with any camera as long as you can get to the back of the camera, some older rangefinders bottom load so they can't be checked without disassembly.
Nick
