Originally posted by Sam_I_am On a side note, Jon no longer includes the bamboo stick with his kits.
_
Well, that's a shame! It is really quite a simple tool, but probably a bit of a pain to make. It is a square bamboo skewer about 3 1/2" long with one end cut into a blunt wedge and the other into a thin scraper. The blunt wedge works well on felt material and the thin scraper on the light trap groove.
As for IPA vs. Ronsonol and control of the solvent. I have not been impressed with isopropanol for foam removal/cleanout and yes, it will attack some plastics, though not as badly as acetone, MEK, or super glue. Ronsonal, OTOH, comes with a cap having a dripper spout to allow for controlled application, has good solvent action against the foam gunk, and does not evaporate too quickly and will not attack paints or plastic. That said, whatever works for you. As far as controlling the solvent, I generally dribble it down the side of the scraper into the groove with a bit of paper towel pressed into the groove an inch or so further down to wick up the excess. The intent is to only have solvent where you need it and nowhere else.
There are a few other things that may not have been mentioned above that you will need:
- A pair of small forceps or tweezers to place the foam parts and also to nibble off the mirror bumper foam. Curved forceps are well-suited to the latter task.
- A pair of cuticle scissors for trimming loose ends
- An X-Acto knife
- Cotton-tip applicators (not the same as Qtip) are useful for spot placement of solvent, particularly for clean-up of residual mirror foam
Have fun!
