Originally posted by brewmaster15 Thank you for your opinion but I disagree on a CLA needing to be done by an expert just to replace light seals. Sure it wouldnt hurt to have it done by expert but its not needed to replace light seals in most/all? cases.Replacement seals and foam is availible... and anyone with a bit of patience and basic diy skills can do it.
I'm not under any illusion and never said you could cure old seals , not sure where you got that from... just to clarify things for you. I asked if there was improved technology and materials since these old camera's were made.. its not an unrealistic question.
Thank you.
You are saying "I could see something like a semi liquid that cures into a seal", but obviously I am misinterpreting that.
I have replaced the seals on most of my film cameras myself, including those for the mirror. But if you want to replace the seals or foam inside the camera, for which the camera must be disassembled, I would recommend sending it to a specialist. That's what I wanted to say.
