06-01-2020, 05:32 AM   #1
Cleaning Tips please
Hello Dear all
Recently I buyed Pentax K1000. She's in mechanical good conditions but I would like to make cleaning maintenance and remove dirt and some corrosion from External parts. (Attached Images9
What's the better solution (Liquid and method) for this?
Thank you very much for your support
06-01-2020, 07:01 AM   #2
E-man's Avatar
Try isopropyl (rubbing) alcohol. It's a reasonably good solvent and it evaporates quickly.
06-01-2020, 07:19 AM   #3
jlstrawman's Avatar
Hard to beat Flitz products:
www.flitz.com
Widely available including Amazon.
06-01-2020, 12:13 PM   #4
Welcome to the forum.
06-01-2020, 11:28 PM   #5
Astro-Baby's Avatar
I would remove the top, for cleaning.
Step 1 wash down with a mild soap solution and a nice soft amd lld toothbrush to remove any loose crumbly bits. Let it dry.
Step 2 a clean down using cotton wool balls and isoprop alchohol. How does it look ? OK or still shabby.
Step 3 apply Brasso which has a mild scour and polish action, work on a small area at a time and test first on a small patch to make sure its not going go cause problems. It may take a lot of rubbing to get it clean. Apply Brasso in a smal, area and buff it off with a soft cloth.
Finally a wash in either warm soapy water and dried and polished with a soft cloth or a wipe down with IPA and a polish with a soft cloth. This is just to make sure any Brasso residue is removed as its quite acidic and given time can mar the finish.
The top looks like it may have pitting in the finish which may not be fixable easily but it can be improved by a clean.
06-02-2020, 12:39 AM   #6
QuoteOriginally posted by Astro-Baby Quote
Yep, what he said^^^
That is corrosion pitting which you won't get rid of. The good news is that its the dirt in the pits which makes it look so bad. I would use IPA or even meths on the end of a cotton tip to clean out the dirt and then apply some polish or sealant to keep the dirt out and to stop the pitting getting worse. Even with the pitting still there, it will look so much better after cleaning.
06-03-2020, 08:56 AM   #7
QuoteOriginally posted by Vendee Quote
I use a soft graphite pencil eg 6B, and a qtip to remove.
You may need several treatments!
07-01-2020, 09:09 PM   #8
ismaelg's Avatar
I have used non-acetone nail polish remover with a cotton swab with good results.
Also, white vinegar followed by isopropyl alcohol to neutralize it.
Then a metal polisher like Blue Magic.
Regardless of what you use the key is working slowly and in small sections checking for progress.
Thanks,
07-01-2020, 11:24 PM - 1 Like   #9
Astro-Baby's Avatar
Something I just tested and used recently was a product called Barkeepers Friend, its a mild scourer. Looks like talcum powder in a bottle.
A little of it goes a long way. You speinkle a small amount onto a damp sponge and polish away. Need to rinse thouroughly afterwards.
Its bought an old cameras top plate up beautifully and removed some staining that was resistant to everything else.
07-04-2020, 10:45 PM - 1 Like   #10
The best technique is ignore,...
But if it is to compelling a 7B artists pencil is soft and works like magic.
Write gently over a spot rub off with cotton wool waste.
There is little risk of liquid penetration.
But ignore is best.
K30 sensor cleaning tips gerax Pentax K-30 & K-50 24 05-16-2015 10:42 AM
Film cleaning tips? sunshine7913 Pentax Film SLR Discussion 10 11-26-2014 02:20 PM
Lens cleaning tips Liney Troubleshooting and Beginner Help 8 08-25-2014 02:04 AM
Dust in the Viewfinder - Cleaning Tips? International9300 Pentax DSLR Discussion 4 06-24-2008 07:45 PM
All times are GMT -7. The time now is 09:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
