Originally posted by c.a.m I have had some success in restoring a couple of camera plates, but I was not able to completely remove the evidence of a dent. I'd say I achieved a 90% level, and I was happy with that.
Here's my basic technique:
- Remove the top plate from the camera.
- The area of the plate to be worked should sit flat and true against a wooden backer (like a dolly). The backer could be held in a vise.
- Use a wooden dowel to gently tap out the dent. The dowel should be slightly oversized to the dented area.
- For the curved section of the plate, a custom rounded backer piece and matching rounded dowel tool could be fashioned from wood.
- Use a lightweight tack hammer. Many light, easy taps.
- Go easy!
You might recognize that the technique is similar to auto body work, but on a much smaller and 'gentler' scale. I don't think you'd need your body hammer and dollies.
Hope this helps.
- Craig
I was thinking shaped dowels as well. Also, I was thinking a bean bag as a backer. They are made out of a thin soft leather filled with fine shot. They conform to the part, add support, and are heavy enough that they do not slide around on a bench. The leather also does not damage the finish.
If all else fails, I can pull out my stud welder and slide hammer, level everything out with filler and base/clear. 😁
Heating up the area and applying dry ice/ice pack can pull out shallow dents, but if there is any kind of a crease or hard edge to the dent it will at least require a combination of techniques.
At least I don't have to worry about cracking the paint. 😄
