07-06-2020, 03:08 PM   #1
Erratic light meter on my MX
Hi, hope you're all well. I have an issue with my MX light meter. The LEDs become unstable when I touch or try to turn the shutter speed dial. They'll flash around for a bit and then usually jump up to the red over expose LED and it will get stuck there for a bit. I usually shoot 400 speed film and can set shutter speed to 1/500 and use aperture to get correct exposure with sunny 16 and the light meter works perfectly in this case. In lower light though, I need to change shutter speed and when I do, the light meter goes haywire. I don't even have to turn the shutter speed dial to create the fault, I can just wiggle it. Just wandered if you guys and girls have any insight on to how I can fix this? Any help would be greatly appreciated.
Matt
07-06-2020, 04:07 PM   #2
pschlute's Avatar
Common problem, mine does the same.
07-06-2020, 05:31 PM - 1 Like   #3
goddo31's Avatar
Mine has done the same in the past.
I also had a problem where the meter would not turn on when the shutter button was pressed softly.
I ended up getting it serviced and it's been fine since then. I don't remember the details of what the technician did, however I know he definately looked at the meter operation.
Perhaps it is an electrical contacts issue?
Also a gentle reminder to check the obvious, that the battery is not going flat
And as a final thought, you could try the facebook group "Learn Camera Repair"
There is a very experienced camera repair guy on that group by the name of Eugene Pate, who is currently posting photos of a very detailed CLA on an MX...
07-06-2020, 06:42 PM - 1 Like   #4
arnold's Avatar
Try exercising the ASA dial and also the speed dial to freshen up the contacts.
07-06-2020, 11:33 PM - 1 Like   #5
Eyewanders's Avatar
QuoteOriginally posted by arnold Quote
This has worked for me on a number Pentax (and other) bodies. ^ ^
Very conservative amounts of electrical contact cleaner applied to those spots to be exercised can also help.
You could likely stand to benefit from a CLA; one would almost certainly address your issues as part of the process.
Dials, solder points and contacts are all in the 40-years-or-older range for the MX now. Cobwebs gots to get cleaned.
07-07-2020, 05:09 AM - 1 Like   #6
QuoteOriginally posted by goddo31 Quote
Thanks for the pointer towards that Facebook group. Such a wealth of knowledge! Eugene knows his stuff.
07-07-2020, 05:10 AM   #7
Thanks for the tip. I'll give it a go
---------- Post added 07-07-20 at 05:25 AM ----------
QuoteOriginally posted by Eyewanders Quote
Thank you for replying. I have looked in to a CLA but I have already replaced the seals, the negatives are perfect so I'm happy that the shutter speeds are correct and the light meter is accurate when the fault isn't present. I know a CLA is much more thorough and would definitely sort out the problem but 120 ($150) for a CLA to fix the light meter fault when the rest of the camera appears to work perfectly, seems too much to pay.
07-07-2020, 10:38 AM   #8
QuoteOriginally posted by mattdavis2412 Quote
I don't know who quoted for your CLA but have you tried Miles Whitehead MWCameraRepairs
He just CLA'd my ME Super for 65 plus postage. The MX might be a bit more but not by much I'd imagine. He did a great job on my camera.
07-07-2020, 02:05 PM   #9
QuoteOriginally posted by Vendee Quote
Thanks for the link. My quote was from Harrow Technical.
07-08-2020, 02:35 AM   #10
Yeah, Harrow Technical did the CLA on my MX a couple of years ago. They were expensive and I wasn't 100% happy with the camera. I felt they didn't really get the metering right. Anyway, as far as I know, Harrow Technical stopped trading a while back although Robin the owner was still doing some work under his own name.
After using Miles Whitehead for my ME Super, I wouldn't hesitate sending my other Pentax bodies to him. I might even send him the MX to get the metering right. Like I said, I was impressed by his pricing.
bit, cla, contacts, fault, light, light meter, meter, mx, shutter
Light meter on my pentax MX not showing 'correct' exposure hit3k Pentax Film SLR Discussion 33 03-08-2020 07:08 AM
Landscape Glacial erratic sunrise The Madshutter Post Your Photos! 17 11-13-2019 11:01 AM
MX light meter LED brightness emlclcy Pentax Film SLR Discussion 8 09-11-2019 08:16 AM
Pentax MX light meter + wind lever film-love Pentax Film SLR Discussion 5 08-07-2019 11:06 AM
K1000 Light Meter Calibration - Aperture has no effect on light meter? appalachian1 Pentax Film SLR Discussion 5 03-14-2017 07:08 PM
All times are GMT -7. The time now is 05:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
