10-13-2020, 09:24 PM   #1
butangmucat's Avatar
Diopters for MX?
I just got my first MX today, and it mostly works (except the light seals, which I do plan to replace with black yarn). However, I realized that with the default diopter, the viewfinder is kind of fuzzy. On my LX, I use a diopter correction of -1.5D, and on my Nikon FM2, I have used both -2D and -4D diopters with good results, so I guess I need a diopter for my MX too. But a quick search here on the user review section and on eBay turned out nothing. I wonder what options do I have for diopter correction on the MX?
Sincerely
P.S. As why I am using a MX now... My LX recently developed a minor fault and was sent out for a second CLA (after two years of good service), so I purchased this MX before sending it out, and the LX got damaged beyond repair by the shipping carrier. Though I am trying to file a claim for that, I guess I will be using the MX for at least quite a while.
10-13-2020, 09:39 PM - 2 Likes   #2
womble's Avatar
Pentax made diopter correctors for the two sizes of eye piece they used: K series cameras and earlier, and M series cameras and later. The M series and later accessories fit everything from the M series cameras right up to the current models. The earlier correctors rarely turn-up on ebay, so most will fit the MX even if they do not explicitly say so.
10-13-2020, 10:31 PM - 1 Like   #3
Otis Memorial Pentaxian
QuoteOriginally posted by butangmucat Quote
This is what was designed for your camera and is the what you probably have on your LX...
PENTAX Diopter Correction Lens Adapter M reviews - Pentax Camera Accessory Review Database
They are actual current product, just not readily available through official channels in North America. I have one on my Super Program and it stays put and works great.
10-14-2020, 06:07 AM - 1 Like   #4
I just got my first MX today, and it mostly works (except the light seals, which I do plan to replace with black yarn). .
Slightly off topic on the subject of black yarn seals. Have you done this before? I tried this on my MX and nearly buggered up the camera. There is a very small hole in the top body channel where the little counter reset lever resides. I was a bit sloppy with a dab of glue and pushed a glue-laden length of yarn into that hole. I had to take the top off to clean the hardened mess out. So don't do as I did and be careful!
Cheers,
Svend
10-14-2020, 07:22 AM   #5
jumbleview's Avatar
There are some on Marketplace right now: Pentax 30735 M -1 Diopter correction lens - PentaxForums.com
I don't have an experience with it so cannot tell how good it is at work.
10-14-2020, 07:31 PM   #6
Purchased Pentax 1 diopter correction for my MX and SuperProgram. On EBay shopped from Japan - perfect for my needs.
10-17-2020, 01:27 AM   #7
QuoteOriginally posted by Viking42 Quote
Cheers,
Svend
I have changed the light seals of a KM before, but I used pre-cut light seal kits back then. So I know that there is a feeler that I must clear for the counter to reset.
This time, I generally followed the method from this video:
The trick is to not completely clean out the gummed foam but leave at least some behind (I just cleaned out the parts that were exposed and making a mess), and directly push the yarn into the channels. The friction alone will let the yarn sit firmly inside the channels, and the leftover gum will act as an additional adhesive to keep the yarn in place. The yarn will also prevent the leftover gum from making a mess in the film chanmber.
10-18-2020, 09:06 AM   #8
This time, I generally followed the method from this video: Fast, Quick, and Permanent Camera Light Seal Replacement using Cotton Yarn - YouTube
Good one! Sounds like you did a much better job than I did
I will bookmark that video. Thanks for posting that. Filed away for the next job...
correction, diopter, diopters, lx, mx
Diopters Sallymay26 Welcomes and Introductions 17 11-10-2020 08:21 PM
Some questions about extension tubes and diopters Ropuchy Pentax Camera and Field Accessories 58 03-15-2019 11:12 AM
For Sale - Sold: SMC Pentax M diopters (-2 & -3) (Worldwide) MJL Sold Items 7 03-22-2011 02:00 PM
For Sale - Sold: Diopters and eyecups ChrisPlatt Sold Items 14 03-27-2009 04:40 PM
77mm Diopters.. Buddha Jones Pentax SLR Lens Discussion 12 06-25-2008 02:24 PM
All times are GMT -7. The time now is 06:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
