Originally posted by stevebrot Thanks for the clarification and function setting reference. I was going from the published specifications and the manual outside of the Pentax Functions. Does the camera give an indication it is using spot metering?
It only indicates that you've locked the exposure with an asterix in the viewfinder, not the basis.
A quick scroll through the Pentax Functions will show, though...
I was fiddling with it a few minutes ago, pointing it at a crystal chandelier, and it did change values when I locked, so it had obviously switched something -- presumably from the averaging metering to spot...
I've always had mine set that way, but I don't know if it's the default or if I just wanted it that way...
-Eric
