Originally posted by stevebrot Welcome to the Pentax Forums!
Does your Super A still work with non-A lenses?
Thanks! Yes, using a non-A lens the diaphragm stops down fine. Also, all the screws etc are tight, and the A lens works as intended on my digital body.
Originally posted by stevebrot With the aperture ring off "A" and in "auto" or "125/X" mode, the viewfinder and top LCD should both display as if a non-A lens were mounted meaning nothing in the right-hand pane in the viewfinder and shutter speed only in the top LCD. I am not sure what you mean by "aperture indication is reversed".
With the ring off A and the camera in auto, the viewfinder shows an aperture, but it does not match the aperture on the ring, and it is actually reversed! Thinking more about this, the camera must still be in program mode. Another look just now has confirmed this: the display keeps showing P. So this is just a weird combination of a manual aperture with P mode, making the camera pick odd aperture numbers to compensate ...
Originally posted by stevebrot RE: aperture not actuating. Does the lens stop down when DOF preview lever is depressed? If not, the lens is probably not fully rotated onto the mount --OR-- the actuator coupling in the body or on the lens is out of alignment or damaged. The coupler on the body should actuate even when no lens is mounted.
This is expected in B mode when the aperture ring is in the "A" position.
With any luck these questions will provide an answer!
The DOF lever works fine. And, the E error is the final clue i think: even with the aperture ring not in the A position, this error shows. So, the camera never detects that the lens leaves A mode! Could this be caused by the lens being too new? It's the PENTAX-FA 77mm 1:1.8. I might have another A lens, some kind of kit zoom, will give that one a test, too.
