Originally posted by womble The ME Super will keep the shutter open on auto for a looooong time in the dark but I very much doubt* it is a usefully measured or timed exposure, let alone allowing for any reciprocity failure issues. As was said above, use B for anything over 4 seconds.
*Polite English way of saying "it isn't"
In testing all my aperture priority capable cameras, I found the following:
All Canons will max out at 30 seconds.
All Minoltas vary up to many seconds but not repeatable.
All Nikons vary up to minutes but not repeatable.
Olympus OM-2, OM-2N and OM4 can vary to minutes. The OM-2 has the longest potential time but subject to many settings. Comprehensive info at ->
Olympus OM-2
All Pentaxes - except for the LX, vary up to many seconds but not repeatable.
Are there any cameras - past or present, that can accomodate for reciprocity failure? All film docs I've seen state the generic test it for yourself and see. The Kodak Ektar 100 doc states, "For critical applications with longer exposure times, make tests under your conditions."
Under controlled lighting conditions, results scanned with my Coolscan with no pre or post work show no color shifts at all.
After these I didn't conduct any more testing as you can't even tell the difference.
The most color variations you will find are from ambient lighting. These from Kodak Ektar 100 - daylight and night shot
