Originally posted by stemked I just picked up a Spotmatic F to replace one that I owned years ago, but I understand the batteries are now hard to find. Anyone have any suggestions?
Thanks!
If you want to use silver oxide cells, your options are virtually nonexistent. The alkaline equivalents (A625PX or similar) are readily available, though finding actual name brand might be a problem. I have several fake Excell in my battery box at present. Amazon is not a reliable source unless "sold by Amazon". Freestyle has Varta and B&H has Excell.
I have an MR-9 (with diode) adapter, but even the SR43 cells I use in that are becoming scarce. As for the MR-9 adapters, those are also hard to source at present, at least in the U.S.. Kanto in Japan can't ship to the U.S. and C.R.I.S is sold out.
An SR44 with an o-ring spacer might also be a solution; thickness is close to that of the 625PX.
Note: Remember that the meter in the Spotmatic F is like that in the K1000 and KM models and is turned on whenever sufficient light reaches the meter. Lens caps are a good idea as might be a case or viewfinder shade.
